Home > In Car Electronics > Nakatanenga DAB antenna
Page 7 of 8 <12345678>
airpusher
Wales 2006 Defender 110 Td5 XS DCPU Zambezi Silver
Hi,
Appreciate this is an old post but I have just fitted one myself and have encountered a problem on the DAB side.
When I fit the supplied booster, the radio shows antenna problem on the screen. The DAB works but I cant do anything.
I’ve tried the booster unpowered, no connection to anything and it pops straight up. I plugged the old window one back in and no pop up.
The radio is a Kenwood DMX7722DABS, has anyone had similar?
cheers 2006 Defender Double Cab- Zambezi Silver
Post #1054596 13th Dec 2024 3:23pm
DSC-off
An earlier post identified the same problem with the Nak splitter,
wyvern wrote:
wyvern wrote:
Hi all
Have just attempted to fit one of these wonderful aerials to my partners 110 which has a Pioneer DEH-S720DAB head unit. It was working with the little stick on the window unit - but not very many channels or good reception.
Since adding the new Nakatanenga antenna (via Brendon and 4x4 overland) I have an ‘Antenna Fault’ message which wont go away no matter how I try and configure the power/ no power to the unit.
I see that PJ2016 had a similar issue with the same head unit as I have but not sure how the issue was fixed .. any pointers ??
Question
Just to follow up for those who are interested ...
The issue with the Pioneer radio was sorted with pressing the reset button under the removable face plate for 5 seconds - then not using the ‘splitter’ provided by Nakatanenga but one from Amazon with a single power connection.
Similar to this one - https://www.amazon.co.uk/LEADSIGN-Splitter...amp;sr=8-5
This works very well and gives up a wider range of stations with good reception.
The Naka one would not work with the radio and constantly caused an 'antenna fault’ warning.
Hope that helps others.
Post #1054598 13th Dec 2024 3:32pm
airpusher
Thank you,
I must have missed that reading through the posts. I’ll try a different splitter like that.
Cheers. 2006 Defender Double Cab- Zambezi Silver
Post #1054600 13th Dec 2024 3:42pm
landy andy
airpusher wrote:
Hi,
cheers
You have to turn the aerial power off on the head unit. And then you power your Nak loom. Fitted mine a few weeks ago. Same headunit as you 👍🏻
Post #1054614 13th Dec 2024 6:16pm
airpusher
Thanks for that Landy Andy, eventually found that option and once I turned it all was well.
Cheers 2006 Defender Double Cab- Zambezi Silver
Post #1055008 18th Dec 2024 3:05pm
Yes, there is a setting for that, which is a bit annoying as you can easily chose the wrong one by accident.
These Antennas make a good Xmas present if you don’t already have one, I’m very pleased with it.
I’ve had one a few years now, works well and is robust.
Ideal that it is always there, so it doesn’t need putting up and also life proof for off road, won’t get damaged green laning etc.
If you want the DAB on, you can just put it on whenever. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1055027 18th Dec 2024 6:25pm
defenderfraggle
Netherlands 2009 Defender 130 Puma 2.4 HCPU Santorini Black
Just installed mine tiday, went Ok.
Have normal fm reception, very bad dab, but do get some stations (badly), but…. It say’s dab antenna error in the screen. It’s a kenwood kmm-bt505dab.
I use the antenna plus (blue white) for plus on booster end radio ground for minus.
Any idea’s how tori this? Do like the antenna looks, but it is not working :/
Jan
Post #1059961 8th Feb 2025 4:39pm
defenderfraggle
Solved! There is a setting in the radio’s system that either powers the dab antenna or does not. As the nalatende has a booster the power is not needed, so in the system you need to set it to off. Works Smile
Found it somewhere hidden on the internet in a Mazda forum hahaha.
I’m happy, I’ll try it tomorrow to test the reception.
Jan
Post #1059962 8th Feb 2025 4:59pm
landy andy
Jan
If you had read my post three up you would have had your question answered Rolling with laughter Rolling with laughter Rolling with laughter
Post #1059985 8th Feb 2025 8:21pm
defenderfraggle
You’re correct, I did, but I misunderstood Smile
Still happy Smile
Post #1059995 8th Feb 2025 11:30pm
defenderfraggle
Hmmm... for some reason the radio does not remember the power off selection. It does remember all other stuff...?
Post #1060296 12th Feb 2025 8:56am
Are you sure it’s retaining permanent 12v feed input? To the HU.
If not it could wipe settings, typically that menu will only come up when power has been completely cut.
So suggests either ground being missing or poor connection, less likely OR being ignition power fed only without permanent 12v _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1060312 12th Feb 2025 10:35am
defenderfraggle
Thanks, I'll check it this afternoon. Are the normal ISO connections and as the memory and all other used setting remain I was thinking all is ok....
I'll check it.
Post #1060318 12th Feb 2025 11:10am
topigo
landy andy wrote:
airpusher wrote:
Hi,
cheers
I am facing same issue and I am not able to change antenna power to off because when window with antenna error is show, screen is freeze and i am not able to touch anything. Radio is same Kenwood DMX7722DABS. Does anyone know how to fix this?
Post #1064274 31st Mar 2025 6:56am
landy andy
Disconnect your antenna. I think your unit is finding a short in the system, so is stalling. Disconnect antenna, then change setting to not power. Then try connecting antenna.
Post #1064319 31st Mar 2025 4:37pm
