Home > Faults & Fixes (L663) > 2020 Defender Engine Failure
MOD_Series_III
France
Morning,
I need some advice on behalf of my brother, he has a 2020 110 Defender which has only done 40k miles and has just been diagnosed with engine failure.
The garage (specialist) has quoted £8.5k + vat to rebuild the engine.
The red engine light came on (now yellow) with a message "Ok to drive with caution - restricted performance". Up until then the car was fine.
The garage have downloaded the codes which do not really seem to make sense.
I believe he has the 2l D240 diesel engine.
He would be gratefully for any ideas / suggestions.
Thanks,
David
Post #1059654 6th Feb 2025 10:43am
lightning
There were issue with the 2.0 Ingenium. Fortunately LR soon stopped using it in the Defender.
Have a search for 2.0 Ingenium engine failures
Post #1059656 6th Feb 2025 11:01am
mse
The 2l ingenium engines are actually quite good, used in far more models in greater volume...
I know in an evoque we had a sensor failed and caused what looked like a engine failure but it was a simple thing and my sisters timing chain failed, which is a known issue - but thats older still Mike
Post #1059662 6th Feb 2025 11:28am
lightning
Were there not issues with oil dilution?
Post #1059705 6th Feb 2025 6:24pm
Telemarkskier
There are oil dilution issues related to repeated incomplete DPF regenerations if the vehicle is used for short journeys. To reach the required temperature diesel fuel is injected into cylinder one on the exhaust stroke. The excess diesel increase the DPF temperature so regen can take place. Unfortunately some of that fuel gets past the piston and dilutes the sump oil increasing engine wear and turbo bearing wear and ultimate failure. In this scenario the turbo ingests the sump oil sending it into the engine causing a run away engine situation where the engine can rev uncontrollably until the whole lot self destructs.
As to the frequency of this happening with the Defender 2.0 diesel, I don't know, hence why I have an extended warranty just in case. 2020 Defender 110 SE 240D: Fuji White.
2011 Freelander 2 SD4 HSE
2007 Freelander2 HSE (man)
Post #1059720 6th Feb 2025 8:22pm
Telemarkskier
Post #1059721 6th Feb 2025 8:22pm
lightning
I haven't read of any issues with the 3.0 diesel.
Post #1066729 30th Apr 2025 8:31pm
lightning
How often was the oil changed? lt really needs to be changed every 6,000 miles on the 2.0 lngenium
Post #1073558 17th Aug 2025 9:51pm
