![]() | Home > Puma (Tdci) > Flat Battery issue |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20841 ![]() ![]() |
And bear in mind various different specs such as the AH rating and CCA spec, those specs have a slight difference in price as well as the size needs to be correct.
The choice is yours. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1117 ![]() ![]() ![]() |
I agree with Ianh and if it helps: last summer, after almost exactly 10 years my factory VARTA LFD90 packed up and I replaced it with an LED95 (95Ah, 850A CCA, EFB, dual purpose).
Note the VARTA LFD90 (90Ah, 800A CCA) was already an EFB and dual-purpose type. The data sheet states 200 cycles at 50% DOD (depth of discharge) and 300 @ 25%. The LED95 is good for 250 cycles @ 50% DOD. This is not to be confused with deep cycle batteries such as an ECTIVE DC 95 which is good for 750 cycles @ 50% but can also cope with 80% DOD (for 450 cycles). That's why they are usually used as leisure batteries. However even that model has a CCA of 840A! ![]() Click image to enlarge |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2361 ![]() ![]() |
Thanks macfrank. One thing, the LFD was dual purpose, but it was a wet , not EFB battery.
Probably right, must have mixed that up
roche1800 Member Since: 07 Apr 2020 Location: derbyshire Posts: 395 ![]() |
Please can someone tell me if the Yuasa is a dual purpose please
![]() Click image to enlarge Just trying to understand the Yuasa HSB 019 100a 900EN (EN is lower than CCA) 5 year warranty Versus the Varta LED95 95a 850cca 2 year warranty (a leisure battery) Many thanks in advance |
The Yuasa HSB 019 100a 900EN is a wet (not EFB) starter only (not dual purpose) battery.
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2258 ![]() ![]() |
That Yuassa battery above is very good and Iv had 2 last over 6+ yrs.
Andyslandytd5 Member Since: 06 Nov 2021 Location: Southampton Posts: 54 ![]() ![]() ![]() |
I Ordered the Varta LED95 a few days ago based on IanH's feedback in another post. Just waiting for it to turn up 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
2004 TD5 90 XS Station Wagon - 2019-2024 2003 TD5 90 G4 LE - 2009-2010 1990 Ninety 6.2 V8 Station Wagon - 2006-2009 |
As an alternative to Varta LED95, has anyone come across Yuasa L36-EFB?
This is cut and pasted from another website, none Land Rover: An alternative to the Varta LED95 (and recommended in the past on this forum) would be this Yuasa battery https://www.tayna.co.uk/leisure-batteries/yuasa/l36-efb/ |
