Home > Puma (Tdci) > Flat Battery issue
Page 2 of 2 <12
Ianh
AS I said in my first post , and others subsequently, I would still test your existing battery ( most decent car parts suppliers can test the battery for you) , and you should test for potential parasitic drain, however it is very likely it’s just age related battery failure.
Post #1059607 5th Feb 2025 7:04pm
And bear in mind various different specs such as the AH rating and CCA spec, those specs have a slight difference in price as well as the size needs to be correct.
The choice is yours. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1059610 5th Feb 2025 7:09pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
I agree with Ianh and if it helps: last summer, after almost exactly 10 years my factory VARTA LFD90 packed up and I replaced it with an LED95 (95Ah, 850A CCA, EFB, dual purpose).
Note the VARTA LFD90 (90Ah, 800A CCA) was already an EFB and dual-purpose type. The data sheet states 200 cycles at 50% DOD (depth of discharge) and 300 @ 25%. The LED95 is good for 250 cycles @ 50% DOD.
This is not to be confused with deep cycle batteries such as an ECTIVE DC 95 which is good for 750 cycles @ 50% but can also cope with 80% DOD (for 450 cycles). That's why they are usually used as leisure batteries. However even that model has a CCA of 840A!
Post #1059637 5th Feb 2025 10:08pm
Ianh
Thanks macfrank. One thing, the LFD was dual purpose, but it was a wet , not EFB battery. Thumbs Up
Post #1059641 5th Feb 2025 10:57pm
macfrank
Probably right, must have mixed that up Thumbs Up
Post #1059648 6th Feb 2025 6:18am
roche1800
Please can someone tell me if the Yuasa is a dual purpose please
Just trying to understand the Yuasa HSB 019 100a 900EN (EN is lower than CCA) 5 year warranty
Versus the Varta LED95 95a 850cca 2 year warranty (a leisure battery)
Many thanks in advance
Post #1059673 6th Feb 2025 1:10pm
Ianh
The Yuasa HSB 019 100a 900EN is a wet (not EFB) starter only (not dual purpose) battery.
Post #1059674 6th Feb 2025 1:57pm
keith
That Yuassa battery above is very good and Iv had 2 last over 6+ yrs.
Post #1059677 6th Feb 2025 2:29pm
Andyslandytd5
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
I Ordered the Varta LED95 a few days ago based on IanH's feedback in another post. Just waiting for it to turn up 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
2004 TD5 90 XS Station Wagon - 2019-2024
2003 TD5 90 G4 LE - 2009-2010
1990 Ninety 6.2 V8 Station Wagon - 2006-2009
Post #1059683 6th Feb 2025 2:49pm
roche1800
As an alternative to Varta LED95, has anyone come across Yuasa L36-EFB?
This is cut and pasted from another website, none Land Rover:
An alternative to the Varta LED95 (and recommended in the past on this forum) would be this Yuasa battery
https://www.tayna.co.uk/leisure-batteries/yuasa/l36-efb/
Post #1060472 13th Feb 2025 1:15pm
Page 2 of 2 <12
