Home > Maintenance & Modifications > Better swivel cam for Optimill reverse cam
Dr Phibes
Australia
Has anyone found a camera that can be swapped with the POS one Optimill include in their Licence plate reverse cam?
Post #1059491 4th Feb 2025 1:31pm
I've been using one of these ever since I fitted the Optimill unit and found that the supplied camera didn't work at all. It does however use a different connector.
I wouldn't exactly call it a great camera, and unfortunately it has those irritating lines automatically superimposed on the image to guide you into spaces, which don't help at all on a Defender since the camera is offset to the nearside.
It does the job though and wasn't expensive.
If anyone knows of a similar alternative that doesn't superimpose the pointless guidelines in the image I would be grateful for a link.
Post #1059499 4th Feb 2025 2:11pm
circlethewagons
Australia 2015 Defender 90 Puma 2.2 HT Aintree Green
Re: Better swivel cam for Optimill reverse cam
Yep, mine gave out within months of owning it, it was too much of a fuss to send it back etc. There are heaps on Amazon available, quite cheap too, I got one for around $80AUD.
Depending on your monitor\headunit\mirror - you can use a AHD camera to get better resolution.
https://www.amazon.com.au/Vtopek-Reversing...&psc=1
Post #1059556 5th Feb 2025 5:42am
Dr Phibes
Australia
Nice. I am looking for an AHD cam. Did that one pop out of the housing and have a swivel ball with spring clips like the original?
Post #1059558 5th Feb 2025 6:08am
Dr Phibes
Australia
Did you disassemble this and take the camera out? I have the same (much cheaper on eBay) and it looks like I will need to cut and resolder the cable to get it out of the housing.
Post #1063333 19th Mar 2025 2:14pm
