![]() | Home > Maintenance & Modifications > Better swivel cam for Optimill reverse cam |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
I've been using one of these ever since I fitted the Optimill unit and found that the supplied camera didn't work at all. It does however use a different connector.
I wouldn't exactly call it a great camera, and unfortunately it has those irritating lines automatically superimposed on the image to guide you into spaces, which don't help at all on a Defender since the camera is offset to the nearside. It does the job though and wasn't expensive. If anyone knows of a similar alternative that doesn't superimpose the pointless guidelines in the image I would be grateful for a link. |
circlethewagons Member Since: 11 May 2024 Location: Brisbane Posts: 27 ![]() ![]() ![]() |
Yep, mine gave out within months of owning it, it was too much of a fuss to send it back etc. There are heaps on Amazon available, quite cheap too, I got one for around $80AUD. Depending on your monitor\headunit\mirror - you can use a AHD camera to get better resolution. https://www.amazon.com.au/Vtopek-Reversing...&psc=1 |
Dr Phibes Member Since: 24 Apr 2024 Location: Melbourne Posts: 71 ![]() ![]() |
Nice. I am looking for an AHD cam. Did that one pop out of the housing and have a swivel ball with spring clips like the original?
Did you disassemble this and take the camera out? I have the same (much cheaper on eBay) and it looks like I will need to cut and resolder the cable to get it out of the housing. |
