Home > In Car Electronics > Arduino/microcontroller based display question.
Welkman
I have been toying with building a display for extra information that the OBD 2 port shows the CPU is measuring. I would like to be able to display:
Oil temp/pressure
Transfer box oil temp
Air temp (external)
Air temp (internal)
This would be a start, then I might add some other bits like a coolant level sensor (I did this in my old TD5).
Has anyone tried this? Is it possible? I know that apps can achieve the same thing with a OBD2 scanner plugged in, but I hate relying on a phone/tablet. I know I can build my own sensors, but it seems silly to duplicate functions that are already monitored.
I loved the MADMAN I had on the TD5, but they have got up to stupid money now. I think I paid £400 8 years ago for a full TD5 kit and now they are closer to £800 if you can find them in stock.
Post #1056734 9th Jan 2025 12:39am
kyvlle
United Kingdom 2004 Defender 110 Td5 XS CSW Epsom Green
I assume you talking about the Td5 engine ECU?
There are projects out there that have already accomplished this:
https://github.com/BennehBoy/LRDuinoTD5
https://github.com/k0sci3j/BinOwl_Td5Gauge
However, don't think the Td5 ECU has sensors for the those parameters you are looking for. No oil temps, but there's a engine air intake temperature.
If you look at BennehBoy's project above, he added the appropriate sensors and read those with his microcontroller.
I'm actually in the process of making one myself, though just relying on the sensors that the ECU has, and report on -- RPM, turbo pressure, etc.
Post #1056735 9th Jan 2025 12:55am
Welkman
Hi - no I am talking about the 2.2 puma ECU. Thanks for the links though.
I normally work on vintage valve radios and amps, alongside older HiFi stuff and some t.v. so programming has been a learning curve, but I love it.
Post #1056832 9th Jan 2025 8:02pm
jonny
Re: Arduino/microcontroller based display question.
Have a look at the https://www.canchecked.de/ devices if you want something off the shelf - they can read data from the OBD port and display it. As the puma uses 'standard' OBD not like the TD5 they should talk to each other.
If you would like a Madman style setup, I have a couple of 'equivalent' gauges without sensors somewhere. From what I understand, Madman is a rebadge of monitoring systems used in light aircraft, other variations of the same gauges are available. You should be able to add standard sensors and get it working...
Post #1056841 9th Jan 2025 9:27pm
pistonfields
Switzerland
I wanted to do the same thing for a while now but haven't found the time, sadly. I think it would be pretty neat to have an open source solution, not only limited to Defenders. There are several projects involving Arduino and OBD2 protocol but I haven't checked for a while if there's a nice one-fits-all-solution.
Reading and displaying values is pretty straight forward, but the moment you want to make it pretty (e.g. use a round display in place of the original clock, with two buttons, nice gauges and so on) it becomes tedious work.
Post #1058126 21st Jan 2025 2:04pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Having lot of numbers and/or indicators is nice, but for real use some sort of settable alarms is important. Just to warn the driver inmediatelly, that something wrong happened. Not waiting for driver to look on the particular value. Settable to be able to customize it easily. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1058323 23rd Jan 2025 12:22pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
There are commercial products available that do this already: Scan Gauge and Ultra Gauge.
However, it is more fun doing it yourself Very Happy
A good place to start is https://www.adafruit.com/product/4759
There's displays and software libs to drive them available too.
Finding the right CAN codes is a challenge Rolling Eyes
I started such a project but have yet to finish it, I'm happy to share any notes I have.
Post #1059320 2nd Feb 2025 9:16pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
This from a German guy: https://github.com/posmanet/DeCANder
He is reporting updates in a German forum: https://www.blacklandy.eu/blboard/vb5/node/156965/page9
Last update a year ago, which hasn't been sync'd to github but you could send him a message.
Post #1059343 3rd Feb 2025 7:32am
khamuul
Germany 2007 Defender 110 Puma 2.4 SW Tonga Green
German guy sync'd his update to github, finally. Mr. Green
Post #1069204 6th Jun 2025 5:11pm
macfrank
Rolling with laughter Thumbs Up
Post #1069205 6th Jun 2025 5:36pm
khamuul
Now the german guy cleaned up the mess in 2.6 and posted 2.7 . Whistle
Post #1069753 15th Jun 2025 3:52pm
psglas
United Kingdom 2012 Defender 90 Puma 2.2 SW Firenze Red
I've been working on something similar but it has a series of external sensors to add other capabilities. Just now I have the following developed :
GPS Speed
GPS Position
Compass
Pitch and Roll
Internal and External Temps
OBD Engine data
Type Pressure sensor data (not shown)
I'm also planning to add parking sensors but I'm just starting on that screen. The display shown is built into one of the double DIN switch panels with a switch to rotate screens. I also have an HDMI version to display on a double DIN input and I'm going to do a separate screen that can be suctioned onto the dash. If anyone is interested in testing this let me know as I'll make it available at some point. I've had a version in one of my Pumas for the last 4-5 months but pulled it out last week to do more development.
Post #1069934 17th Jun 2025 9:46pm
Screbble
Very impressive Thumbs Up
Post #1069942 17th Jun 2025 10:39pm
steveww
Excellent idea using the switch module. It's always where my projects stall, putting them in a box.
Which display are you using?
Which processor, Arduino?
How about showing fuel economy or is that irrelevant when driving a Defender?
Post #1069965 18th Jun 2025 1:24pm
psglas
It's actually a raspberry pi zero 2, not an arduino, with a round hyperpixel display. The display is very sharp and looks great in real life.
I'm just in the process of figuring out the available OBD data from the Puma Defender's. I have an early 2.4 and a 2.2. The data from the 2.4 is fairly limited.
Post #1069996 18th Jun 2025 9:29pm
