Home > In Car Electronics > Arduino/microcontroller based display question.
Page 2 of 2 <12
circlethewagons
Australia 2015 Defender 90 Puma 2.2 HT Aintree Green
Really well done, You could replace the centre clock too with that round display.
Post #1070101 21st Jun 2025 10:40am
sako243
Little bit more extravagant but I built this for a friend's sort of Land Rover (it's all LR parts but a custom race buggy). Some senders read directly (including Td5 speedo transducer) but a fair chunk of the information is pulled over CAN bus from the Megasquirt ECU running it.
Slightly related but I've also been building this which is a CAN triggered relay. A prototype is winging its way to Sweden for testing - basically to listen to the message broadcast from a P38 ECU with coolant temperature and uses it to switch in a radiator fan. It will become more generic shortly.
 Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #1070122 22nd Jun 2025 9:05am
macfrank
Bow down
Post #1070154 22nd Jun 2025 8:21pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
That's exactly the same thought I had. I'm looking through the usual suppliers to find one that will do the job. It will be a project for the winter. It solves the usual problem I have with projects like this, building some form of case to hold the electronics.
I'll post all the details on GitHub when it's finished.
Post #1070404 27th Jun 2025 10:20am
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
would you reckon it would work on my M57 swap and auto box, i'm using a 2.4 loom and obd port works for engine diagnostic
Post #1070623 1st Jul 2025 11:32am
steveww
OBD is standard on all modern vehicles. It will work for most common PIDS.
https://en.wikipedia.org/wiki/OBD-II_PIDs
Post #1070633 1st Jul 2025 5:10pm
psglas
United Kingdom 2012 Defender 90 Puma 2.2 SW Firenze Red
I'm getting very close to having the following working with an external round display that could be mounted on a small suction arm on any defender. It can also be mounted in the switch panel with the round gauge hole. It's probably too big for the TD5 clock.
Clock
GPS Speed
GPS Position
Compass
Pitch and Roll
Temperatures (In and Out)
Type pressures (From internal or valve mounted sensors)
Parking Sensors (From wired bumper sensors)
Engine Data (Various OBD data)
The only screen that is car/ECU dependent is the engine data screen.I have a Puma 2.2 and a 2.4. The 2.2 has some useful fields, the 2.4 has less (no oil temp and fuel level obd pids). Once I have everything else working I will try talking directly to the CANBus.
A few questions for anyone willing to help :
- what's the diameter of the TD5 clock
- any other screens you think I should add. I was going to add a battery monitor screen but it's not so useful when the engine is powered on. I also have the voltage on the engine screen
- an information on reading the CANbus would be helpful
I'll post some screenshots when I have everything working.
Post #1070697 2nd Jul 2025 5:27pm
steveww
I have working knowledge of Arduino and CAN bus, PIDS, etc.
PM me with any questions.
One question for you. You're using a RPI Pico, how do you manage controlled shutdown for it?
Post #1070700 2nd Jul 2025 6:06pm
excossack
I'd thought about doing something similar but instead of reading OBD info, I was thinking of reading direct from each sensor....somehow using an Arduino.
I never got passed the pondering stage. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1070738 3rd Jul 2025 10:35am
myp38me
Clock
GPS Speed
GPS Position
Compass
Pitch and Roll
Hello, is my first post and not even driving an Defender.
I'm looking for something similar for the RR P38. There is a clock just waiting to get replaced by something smarter.
Maybe we can help each other.
Post #1071322 12th Jul 2025 8:44pm
psglas
The screen I'm currently working with has a visible size of 52mm. The system isn't specific to a Defender so no reason why it can't be used on other vehicles.
I now have all of the following working in my lab.
Clock
GPS Speed
GPS Position
Compass
Pitch and Roll
I'm just installing it in my defender then I'll do a video to demo the unit. If anyone is interested in this please DM me as I'm considering building a small batch for others to test out. I'll need to order a batch of the electronics. I have a contact over in China who maybe able to help me source various screens and batches of the various electronics.
Post #1071343 13th Jul 2025 10:44am
myp38me
Hello,
The system doesn't let me PN you directly.
The display in total is a little bit big for the space the analog clock gives in the P38.
If you don't mind I would like to talk about the concept.
My plan was to use an AMOLED 1,7'' with an ESP32-S3 attached behind it to run my setup. This comes with a speaker and GPS and battery for RTC so pretty much what you need.
For the TPMS I would use Bluetooth what protocol you use?
How do you fetch the OBD2 Data?
Post #1071345 13th Jul 2025 2:28pm
steveww
I'm using an ESP32 display with integrated RTC & 6DOF. I use an Arduino to talk to the CAN bus and I2C to chat between ESP32 and Arduino. Still work in progress but I'm happy to share code that I have so far.
Post #1071868 21st Jul 2025 10:35am
Page 2 of 2 <12
