![]() | Home > In Car Electronics > Arduino/microcontroller based display question. |
| circlethewagons Member Since: 11 May 2024 Location: Brisbane Posts: 28
Really well done, You could replace the centre clock too with that round display.
| macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1138
| steveww Member Since: 05 Jan 2022 Location: Malton Posts: 612
That's exactly the same thought I had. I'm looking through the usual suppliers to find one that will do the job. It will be a project for the winter. It solves the usual problem I have with projects like this, building some form of case to hold the electronics. I'll post all the details on GitHub when it's finished. |
| shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 551
would you reckon it would work on my M57 swap and auto box, i'm using a 2.4 loom and obd port works for engine diagnostic
OBD is standard on all modern vehicles. It will work for most common PIDS.
https://en.wikipedia.org/wiki/OBD-II_PIDs |
| psglas Member Since: 20 Jun 2019 Location: Aviemore Posts: 32
I'm getting very close to having the following working with an external round display that could be mounted on a small suction arm on any defender. It can also be mounted in the switch panel with the round gauge hole. It's probably too big for the TD5 clock.
Clock GPS Speed GPS Position Compass Pitch and Roll Temperatures (In and Out) Type pressures (From internal or valve mounted sensors) Parking Sensors (From wired bumper sensors) Engine Data (Various OBD data) The only screen that is car/ECU dependent is the engine data screen.I have a Puma 2.2 and a 2.4. The 2.2 has some useful fields, the 2.4 has less (no oil temp and fuel level obd pids). Once I have everything else working I will try talking directly to the CANBus. A few questions for anyone willing to help : - what's the diameter of the TD5 clock - any other screens you think I should add. I was going to add a battery monitor screen but it's not so useful when the engine is powered on. I also have the voltage on the engine screen - an information on reading the CANbus would be helpful I'll post some screenshots when I have everything working. |
I have working knowledge of Arduino and CAN bus, PIDS, etc.
PM me with any questions. One question for you. You're using a RPI Pico, how do you manage controlled shutdown for it? |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
I'd thought about doing something similar but instead of reading OBD info, I was thinking of reading direct from each sensor....somehow using an Arduino.
I never got passed the pondering stage. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| myp38me Member Since: 12 Jul 2025 Location: NRW Posts: 3
Hello, is my first post and not even driving an Defender. I'm looking for something similar for the RR P38. There is a clock just waiting to get replaced by something smarter. Maybe we can help each other. Click image to enlarge Click image to enlarge |
The screen I'm currently working with has a visible size of 52mm. The system isn't specific to a Defender so no reason why it can't be used on other vehicles.
Click image to enlarge I now have all of the following working in my lab. Clock GPS Speed GPS Position Compass Pitch and Roll Temperatures (In and Out) Type pressures (From internal or valve mounted sensors) Parking Sensors (From wired bumper sensors) Engine Data (Various OBD data) I'm just installing it in my defender then I'll do a video to demo the unit. If anyone is interested in this please DM me as I'm considering building a small batch for others to test out. I'll need to order a batch of the electronics. I have a contact over in China who maybe able to help me source various screens and batches of the various electronics. |
Hello,
The system doesn't let me PN you directly. The display in total is a little bit big for the space the analog clock gives in the P38. If you don't mind I would like to talk about the concept. My plan was to use an AMOLED 1,7'' with an ESP32-S3 attached behind it to run my setup. This comes with a speaker and GPS and battery for RTC so pretty much what you need. For the TPMS I would use Bluetooth what protocol you use? How do you fetch the OBD2 Data? |
I'm using an ESP32 display with integrated RTC & 6DOF. I use an Arduino to talk to the CAN bus and I2C to chat between ESP32 and Arduino. Still work in progress but I'm happy to share code that I have so far.
