![]() | Home > Td5 > Driver demand problem 1 fault |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Sounds like it is over-boosting. Either sticky waste gate or incorrectly adjusted. Do you have a boost gauge? |
| balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 196
No, but I have a nanocom, just starting to look at logs now
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
It can be logged sometimes if someone messes with the pedal or pumps it like a looney.
It seems it was, and the cause the waste gate. It built up to 1.33 bar, then drops and wont recover above 1.03 bar until stopped and restarted. Taken the heatshield off this afternoon and waste gate was almost completely solid. now loosened up and the problem seems to have gone. |
| flatfrog Member Since: 04 Mar 2018 Location: East Yorkshire Posts: 5
Hi, this may be the same problem - driver demand not responding BUT when started with pedal pressed down it revs like crazy and continues to respond until its allowed to idle, then yellow engine light comes on and stops responding. Is this likley to be the loom or something else - any thoughts? Thanks, Mike
| All times are GMT |
