Home > Technical > Stock TD5 Aircon Improvement
Page 2 of 2 <12
Dr Phibes
Australia
You mean you have the condenser and it abuts the frame? I haven’t got mine yet but think it should be fine mounted in any orientation as it is pressure fed.
The blower is apparently 223cfm, 3 speed. I haven’t got it yet but it doesn’t look like a perfect fit- will have to adapt. Also need to confirm if I need to replace control unit with another one - assume PWM.
https://www.sparesbox.com.au/products/oex-...ded-emx009
Post #1053183 28th Nov 2024 9:47am
Zimblewinder
Australia 2000 Defender 130 2.5 TD HCPU Chawton White
Hi there, not sure how far along you are Dr but found this on Alibaba. Have a look at the first universal unit. It is exactly the same as the AMC kit used in Australia only with a different vent box riveted on the front(could remove and use the original vent set instead). For $260 for the lot it's a steal. There is also another unit in the pictures which has four outlets for plumbing which might also be a good setup for improved venting.
https://www.alibaba.com/product-detail/Uni...68595.html
Post #1053393 29th Nov 2024 10:13pm
Dr Phibes
Australia
I have the condenser and blower. I have confirmed the blower housing is oversize (marginally) and that the OEX motor will fit the original housing. I just need to get the old blower fans off and put on the shafts.
Post #1053403 29th Nov 2024 11:45pm
Page 2 of 2 <12
