Home > Faults & Fixes (L663) > Stop Safely Electrical Fault Detected - D250 Problem
Page 1 of 3 123>
91dm
Ireland
Hello,
Looking for a second opinion on this:
Stop safely
Electrical fault detected
This appeared last week after a first start up, I had just put the heater on and auto lights on. Switched on and off a few times but didn't change. I checked with a meter and it was showing only 11 volts when running. After a few starts and opening doors it was showing a low voltage message.
I'm annoyed because I forgot to plug it the scanner before Land Rover collected it. I was expecting them to say the alternator was at fault but they're saying it needs a new battery.
Can a bad battery cause the alternator to not 'trigger' and start charging?
Any advice appreciated.
Thanks
Post #1052946 25th Nov 2024 10:00pm
lightning
l've read of a few owners having a faulty battery, if the battery won't take a charge the vehicle will show a "low voltage" fault.
Hopefully the new battery will resolve the problem on yours.
Post #1052971 26th Nov 2024 9:30am
91dm
Ireland
Funny mine didn't show a low voltage until it was running for awhile.
I've done lots of google searching today and read someone had a DC/DC converter and battery issue which resolved it.
The Belt Integrated Starter Generator (BISG) issue seems to be on later models and I checked my VIN online which shows no recalls.
I find it hard to believe a new battery didn't last 3 years?!
Post #1053041 26th Nov 2024 8:54pm
nebc100
Luxembourg
I had this with my P400 the day after I bought it.
That same day a recall was announced for the software update for the “alternator” (no longer called alternator and too early to remember the correct term)
Since I had the update done, no issues at all.
Post #1053071 27th Nov 2024 6:40am
Fifth Horseman
SSM76173 refers to this:
Quote:
Note:
This SSM is only applicable to vehicles installed with the following part numbers:
Service part number - Direct Current to Direct Current (DCDC) Converter 433123456 (N8B214B227AC)
Service part number - Harness 419123816 (R8E214N178AC)
Situation:
Certain vehicles are displaying a 'Stop Safely Electrical Fault Detected' warning message on the instrument panel. In some cases, a loss of 12V charging may also be experienced. Visible signs of damage to the connectors of the 48V DCDC converter and connector harness may also be present.
Cause:
Internal failure in the 48V DCDC converter.
Post #1053609 1st Dec 2024 11:21pm
91dm
Ireland
Thanks Fifth Horseman, very useful sounds exactly my issue.
The garage told me last week they thought it was now the DC converter but haven't heard anything since.
Post #1053944 5th Dec 2024 9:49pm
Are you sure the brake fluid doesn’t need topping up to the maximum mark, if it isn’t it’ll send signals back to the ECU of brake faults.
It does this on a Puma, so might be a thing to look at anyway..
You never know. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1053946 5th Dec 2024 9:55pm
91dm
Ireland
The latest from the garage is new DC converter to be fitted next week. Will update how it goes.
Post #1054134 8th Dec 2024 11:05am
DrRob
Did the new DCConverter solve this? MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie"
Many Range Rovers and Land Rovers over the years 😂
1949 80" - still in family since 1975
Post #1059416 3rd Feb 2025 7:44pm
91dm
Ireland
Yes new converter seems to have fixed it, I’ve done 1k miles since and no faults.
Post #1059542 4th Feb 2025 8:10pm
DrRob
Good news Thumbs Up MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
Post #1059543 4th Feb 2025 8:17pm
DrRob
Mine was trailered off on Monday with same suspected fault. Totally dead battery.
Awaiting full diagnosis from main dealer
6 months old and 3500miles. Ridiculous Rolling Eyes MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
Post #1059621 5th Feb 2025 8:22pm
Nicholls.p
Mine got flat bedded back to the dealership as it came up with the electrical fault detected, couldn’t continue the journey. Defender 110 is under 2 months old and been told its the dc converter which has gone and that its on back order and could take 8 weeks. Got told that there is a fair few in for the same problem.
Post #1059739 6th Feb 2025 11:27pm
lightning
Bad batch of converters? Never had an issue with mine in two years/18,000 miles. l very rarely use the stop/start though. Could this make a difference?
Will probably fail once out of warranty
Post #1059762 7th Feb 2025 9:20am
DrRob
If it's 2 months old from new then you can simply reject it. After 6 months it's a lot trickier Rolling Eyes MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
Post #1059769 7th Feb 2025 9:52am
Page 1 of 3 123>
