![]() | Home > Puma (Tdci) > New Owner Issue |
Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589 ![]() ![]() ![]() |
Including the tightness of the turbo hose
Silverspeed Member Since: 07 Jul 2024 Location: Leicestershire Posts: 14 ![]() ![]() ![]() |
Did this throw a fault code of dash warning light ? |
Thanks - turbo and actuator were replaced early doors however i have positive news. Lots been done to the vehicle as already noted including some recent replacement wiring however nothing sorted the intermittent loss of power with no MIL or codes . As pretty well everything on the car was either tested or replaced the techs were left with one final area to look at - the ECU . This was replaced on Tuesday and since then no loss of power - in fact increase in boost , much better MPG and everything looking positive . Further road tests next week but fingers crossed will be back home on Thursday . It’s been a long journey but I now have a better understanding of the car thanks to everyone’s input . |
Waka56 Member Since: 08 Nov 2023 Location: Hamburg Posts: 171 ![]() ![]() |
An understanding, and lots of new parts!
Hope it is now sorted for a while ![]() |
cozz Member Since: 15 May 2013 Location: nottingham Posts: 548 ![]() |
sounds like you had a bad un, which hopefully is now a good un with loads of new parts that will serve you well
all the best |
So my Defender is now back - done about 80 miles in it and so far so good - pulls much stronger and mpg is amazing ( compared to before ) . New ECU seems to have done the trick . Now to start the little jobs like why the interior lights don’t come on with door open and rear centre brake light non op . Little jobs I don’t mind working on and expected when I bought it . Does anyone know how to replace the clock bulb - is it the whole centre fascia out or does the clock come out separately to get to the bulb - assuming of course it does light up ?
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18028 ![]() ![]() ![]() |
Centre fascia out to get at back of clock. Easy job but odd bulb!
