Home > Puma (Tdci) > New Owner Issue
Page 3 of 3 <123
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Including the tightness of the turbo hose
Post #1048148 9th Oct 2024 5:03pm
Silverspeed
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Corris Grey
Julie wrote:
If turbo is not in good condition, thé engine will loose power and rpm
Thanks - Turbo has been replaced when they had boost fault code .
Post #1048149 9th Oct 2024 5:06pm
Silverspeed
Julie wrote:
Rescue01 wrote:
I had a leak on my inlet manifold gasket which was doing the same thing. Wouldn’t rev above 2500rpm. Switched off and ran fine for a bit then same again. Worth a look.
Did this throw a fault code of dash warning light ?
Post #1048150 9th Oct 2024 5:09pm
Silverspeed
Thanks - turbo and actuator were replaced early doors however i have positive news. Lots been done to the vehicle as already noted including some recent replacement wiring however nothing sorted the intermittent loss of power with no MIL or codes . As pretty well everything on the car was either tested or replaced the techs were left with one final area to look at - the ECU . This was replaced on Tuesday and since then no loss of power - in fact increase in boost , much better MPG and everything looking positive . Further road tests next week but fingers crossed will be back home on Thursday . It’s been a long journey but I now have a better understanding of the car thanks to everyone’s input .
Post #1050527 2nd Nov 2024 12:37pm
Waka56
Germany
An understanding, and lots of new parts!
Hope it is now sorted for a while Thumbs Up Making my Defender great again. (Or trying to at least xD)
Post #1050741 4th Nov 2024 7:29pm
cozz
sounds like you had a bad un, which hopefully is now a good un with loads of new parts that will serve you well
all the best
Post #1050852 5th Nov 2024 10:47pm
Silverspeed
So my Defender is now back - done about 80 miles in it and so far so good - pulls much stronger and mpg is amazing ( compared to before ) . New ECU seems to have done the trick . Now to start the little jobs like why the interior lights don’t come on with door open and rear centre brake light non op . Little jobs I don’t mind working on and expected when I bought it . Does anyone know how to replace the clock bulb - is it the whole centre fascia out or does the clock come out separately to get to the bulb - assuming of course it does light up ?
Post #1051232 10th Nov 2024 1:43pm
Centre fascia out to get at back of clock. Easy job but odd bulb!
Post #1051239 10th Nov 2024 3:14pm
Page 3 of 3 <123
