![]() | Home > Maintenance & Modifications > Rust converter |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1030 ![]() ![]() ![]() |
It’s not worth the hassle. Just buy some ACF-50 and it’ll kill most of your rust issues. 2017 L494 Range Rover Sport SVR
2008 2.4 110 Utility Station Wagon XS. |
Use dilute phosphoric acid (25% w/w) which is widely available and inexpensive and will turn your ferric oxide into ferric phosphate.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3600 ![]() ![]() ![]() |
For smaller / manageable parts, I remove the bulk of the rust using electrolysis - google is your friend to find how it works. After electrolysis, I then use a rust remover (not converter). For rust removal I use a product manufactured by Hg - https://hg.eu/uk/products/hg-rust-remover
Its not expensive, and I only brush it on, and a small 500ml bottle goes a long way. On my restoration thread there are 2 pics after I applied it to my chassis. But was only surface rust it had to deal with. Nevertheless always pleasant to see clean metal. https://www.defender2.net/forum/topic72365-135.html 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1067 ![]() ![]() ![]() |
How well does electrolysis work? I suppose that in theory we could connect our Defender chassis to a trickle charger of some sort and spray part of the chassis with an electrolyte.
Just make sure it's plugged in the right way round! |
With that method, you would need your cathode only a film thickness away from the chassis.
I think Ed's China method of dipping the chassis is much better, the difference is that the electrolyte would literally cost pennies. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
I 'just' need to spend £20k on Evaporust!
