![]() | Home > Maintenance & Modifications > ***URGENT BRAKE ISSUE*** |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3748 ![]() ![]() ![]() |
Thanks Andrew,, best check them in the morning
![]() Main Brian James Trailer Dealer for South West UK |
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
![]() Thanks for bringing this up mate. Ours is ok, but I'll be adding a couple of cable ties tomorrow just in case. ![]() ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
Milligan Member Since: 07 Dec 2007 Location: Somerset Posts: 32 ![]() ![]() ![]() |
Andrew
I think that the clip is just one potential issue... On mine the pipe was in the clip, however the brake pipe was still touching the heat shield! This was because the pipe and fitting with the brake housing had been pushed down, all i did was to turn (the fitting and thus the pipe) anti clockwise and now the pipe now sits above the shield instead of touching it. The pipe is however also touching the pipe heat shield by the exspansion bottle just visible in your picture ! Is that a problem? Thanks for raising this issue. ![]() Matt Now:- 90 XS CSW Java Black Then:- 90 CSW Oxford Blue |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 ![]() ![]() ![]() |
In theory nothing should loosely touch anything. If things are touching they should be fixed together. If you know what I mean. I think that made sense.
goneriding Member Since: 03 Dec 2007 Location: Forest of Dean Posts: 2 ![]() ![]() ![]() |
Thanks for the tip-off. Mine was fine, but still cable tied anyway.
Martin can we make this post sticky or start a new heading 'Things to check before you die' and move it to said area.
