Home > Maintenance & Modifications > ***URGENT BRAKE ISSUE***
My brake pipe was touching the heat shield.
Yes
42%
 42%  [3]
No
57%
 57%  [4]
Total Votes: 7
AndrewS
Please check your brake pipes where they pass the turbo/exhaust heat shield. The pipes on The Red Dwarf had come unclipped and had rubbed against the heat shield which resulted in a pipe rupture and brake failure Shocked I would also recommend that if you can, cable tie the pipes back so they don’t spring out of their clips. Can you please report here if your pipes were un-clipped, loose or touching the heat shield? Hopefully it’s just my car that’s suffered.
Its difficult to take pictures of the exact place but I am sure you will get the jist from these pics.
Oh don’t check if your engine hot as you may burn your pinky’s.
Post #1016 8th Jan 2008 3:54pm
TJ101
Thanks Andrew,, best check them in the morning Shocked California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1031 8th Jan 2008 6:07pm
NoDo$h
Shocked
Thanks for bringing this up mate. Ours is ok, but I'll be adding a couple of cable ties tomorrow just in case. Bow down
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #1032 8th Jan 2008 6:11pm
Milligan
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Andrew
I think that the clip is just one potential issue...
On mine the pipe was in the clip, however the brake pipe was still touching the heat shield! This was because the pipe and fitting with the brake housing had been pushed down, all i did was to turn (the fitting and thus the pipe) anti clockwise and now the pipe now sits above the shield instead of touching it.
The pipe is however also touching the pipe heat shield by the exspansion bottle just visible in your picture ! Is that a problem?
Thanks for raising this issue. Bow down
Matt Now:- 90 XS CSW Java Black
Then:- 90 CSW Oxford Blue
Post #1047 9th Jan 2008 10:23am
AndrewS
In theory nothing should loosely touch anything. If things are touching they should be fixed together. If you know what I mean. I think that made sense. Embarassed
Post #1048 9th Jan 2008 12:17pm
goneriding
United Kingdom 2007 Defender 90 Other XS CSW Java Black
Thanks for the tip-off. Mine was fine, but still cable tied anyway.
Rolling Eyes
Post #1053 10th Jan 2008 12:44pm
AndrewS
Martin can we make this post sticky or start a new heading 'Things to check before you die' and move it to said area. Thumbs Up
Post #4070 28th Sep 2008 11:14am
