Page 1373 of 1391 <123 ... 137213731374 ... 138913901391>
excossack
Started scrubbing the roof of the 110 as I had left it far too long and green algae had moved in, settled down, had some adult time and created more roof top algae.
Having a roof rack it was difficult to get the algae off, ended up using a well used scouring pad to help remove the algae. I still have some stubborn algae to remove and might need the use of some anti-algae spray to help soften it up.
Fitted some Disco3 parts to the Defender......................Well when I say Disco3 parts what I mean is, I replaced the rear door lock captive plate and the bolts I needed are from a Disco 3 - same part number as Defender parts Smile FS106206 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1041908 5th Aug 2024 8:52am
AJC
MK wrote:
Very serious roof tent setup. Any more pictures?
i haven't sorry, i hardly ever take pictures and got the one i posted off my son.
Post #1042038 6th Aug 2024 7:33am
excossack
Hoovered the 110(Tuesday)
Washed the 110(Tuesday)
Waxed/polished the 110 all round - yesterday
Cleaned all the windows to remove the water marks
Back to black on the wheel arches
Back to black on the mirror heads
Removed front LED spot lights to give them a tidy up / paint as the paint was flaking off 1999 Defender TD5 110
Regards
John M0VAZ
Post #1042194 8th Aug 2024 8:05am
ChrisDefender
Got a few bits to do to keep it looking up to scratch, mainly in the rear tub.
Also decided some new wing mirror arms were in order and decided to spruce up the mirror heads whist I was at it as I get fed up of them keep fading. Prepped, sprayed with adhesion promotor and then Raptor, which will match the side sills, sidesteps, wing chequer and front grill, all of which look as good as the day I did them, some over 4 yrs ago (grill pic attached).
The overly shiny finish will go after a while outside.
Post #1042217 8th Aug 2024 12:23pm
Xtech.Ell
United Kingdom 2011 Defender 90 V8 Petrol X-Tech LE Auto Orkney Grey
Fitted new wiper wheel boxes and a new motor cable as mine was extremely dry and wheel boxes were worn.
Bought the design development stainless steel units, excellent quality!
Dash isn't such a bad job to remove, just long winded. 2011 90 X-tech
6.2 LS3 V8
Post #1042491 11th Aug 2024 2:42pm
Yes, that that is it with that job it’s not a hard job or overly complicated it is just time consuming and a bit unwieldy.
This time of year is the time to go do that job.
Also for periodically using washwipe so wiper arms don’t stay static for months with no rain, it’s this time of year and towards the autumn they can seize up due to lack of use.
Then you get some rain, or an MOT coming up and then they don’t work and the weather is bad and then it’s the worst of both worlds then. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1042501 11th Aug 2024 4:16pm
excossack
Last week I got around to greasing the prop shafts. Some grease needed...But what I did notice was (coincidence?) that a vibration that I had at around 60mph had gone and the drive felt smoother... 1999 Defender TD5 110
Regards
John M0VAZ
Post #1042541 12th Aug 2024 8:06am
Greased my clutch pedal box, A frame ball joint, Prop sliders and prop UJ’s.
Not a lot that is very exciting, but well worth doing - I do mine approx every quarter.
Ideal weather for it too, nice and warm after coming back from a run the grease will flow better due to ambient temperature.
Very Happy _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1043337 20th Aug 2024 6:33pm
Excossack - Coincidence I just noticed your post after I had posted, funny enough the prop shafts greasing. Laughing
Slight imbalance / vibration, does happen I think it’s perhaps where some grease can be in some bearing cups and not others.
As Blackwolf has mentioned before IIRC with the UJ spider centre greasing point it isn’t an ideal greasing method as it’s injected from the centre and not in each bearing cup.
So the grease can take the path of least resistance, so if one bearing cup gets solidified grease in it then it’ll pump out of another instead. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1043340 20th Aug 2024 6:45pm
excossack
That sounds like the issue I had with my UJs out of balance. So far they seem OK - I might add a bit more grease now I have done a few hundred miles. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1043406 21st Aug 2024 8:20am
LR90XS2011
I need to bow my head in shame, a couple of weeks ago the DEF wouldn't start, in true fashion this happened in the middle of Wales 100miles from home and a 2 mile walk just to get a phone signal. RAC came 2 hrs later and it started so I drove home without stopping and then it wouldn't start again.
Ian from IRB answered his phone and had the car after some lengthy diagnosis and changing a couple of sensors he diagnosed that I had refuelled with petrol!!!
As this was only about 25% of the fuel it would start when cold but not when hot.
Hence I need to apologise to anyone waiting Ian's attention as I just wasted a load of his time!!
How I managed this for the first time after 43 yrs of motoring I cannot explain but it wont happen again. DEFENDER 90 TDCI XS,
Post #1043500 21st Aug 2024 10:03pm
revd
hope there is no damage to the fuel pump, petrol lacks the lubricating properties of diesel
Post #1043795 24th Aug 2024 11:20pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Sunday, popped along to the Leafers at t' pit gathering at Apedale Valley Light Railway.
First Land Rover event I think I've visited in several years, and the first time I've attended this event since its move from Wakefield National Coal Mining museum. What I hadnt appreciated when I briefly looked into going was the Light Railway is a smaller venue alongside the Apedale Heritage Centre, which is essentially another mining museum.
Great range of leafers in attendance, although sadly I didnt get chance to get pictures of all of them, especially the Dormobile and Carawagon parked side by side which were great looking vehicles. Chatted to the owners for a few minutes to discuss the relative merits of each roof system as I've never seen a Carawagon in the flesh before.
Whilst we were there it would have been rude not to spend a little time exploring the railway and the heritage centre, including a tour round the old drift mine workings, (which having visited The Big Pit in South Wales last month, this was a better tour).
My lads got to have a crack at being a train driver. Shot of the youngest paying no attention to any of the instructions.
Ride the narrow gauge railway - if you visit dont but the all day rover ticket!
And a final shot especially for Clayton as we know he loves a good Ford
 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #1044010 27th Aug 2024 3:09pm
Great pictures. Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1044012 27th Aug 2024 4:16pm
seriesonenut
Loving the Transit. Probably now nearly worth its weight in gold! Big Cry 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #1044022 27th Aug 2024 5:22pm
