|  | Home > Puma (Tdci) > Puma 2.2 metal in sump |
| Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 628    | Looks like a head to block locating dowel. They can’t get out whilst engine is assembled though | ||
|  1st Jul 2024 7:29pm |
| Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 628    |   Click image to enlarge | ||
|  1st Jul 2024 7:30pm |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512      | For a peace of mind I would compare with TYT500020 or LR004348 Puma 110" SW
 ............................................................. Earth first. Other planets later | ||
|  1st Jul 2024 10:56pm |
| Ambo_Chris Member Since: 01 Dec 2021 Location: South West Posts: 32      | Fantastic, good news I guess? 2013 Baltic Blue 110 Utility Station Wagon XS 2.2
 2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) | ||
|  2nd Jul 2024 7:48am |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2553    | Unless someone has had the engine apart then I suspect the dowel has been in their from assembly. Hopefully it’s not missing from the engine, just a “spare “ that the ford kindly left in your sump in  case you ever needed it.   The sump has its own magnet so given you have an aftermarket magnetic drain plug I guess it dislodged from the sump magnet and attached to the plug magnet. | ||
|  2nd Jul 2024 11:04am |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512      | I was not aware the oil sump had a magnet. Puma 110" SW
|  2nd Jul 2024 4:29pm |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2553    | Sorry , having a brain fade today, it’s the gearbox that has a magnet fitted, not the engine sump. | ||
|  2nd Jul 2024 6:11pm |
 It is a replacement engine done by the previous owner. Not sure of the source but it is a later engine with the screw on type oil filter rather than the insert type. 2013 Baltic Blue 110 Utility Station Wagon XS 2.2 2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) | ||
|  4th Jul 2024 6:48am |
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363      | Did you fit the magnet at that last oil change 2000 miles ago? Strange for that dowel to appear now and not then > 110 XS Double Cab | ||
|  4th Jul 2024 7:58am |
| Ambo_Chris Member Since: 01 Dec 2021 Location: South West Posts: 32      | No I’m pretty sure it was already on there and obviously there was nothing on there then. 2013 Baltic Blue 110 Utility Station Wagon XS 2.2
|  5th Jul 2024 5:14pm |
| Posting Rules
