![]() | Home > Puma (Tdci) > Puma 2.2 metal in sump |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 615 ![]() ![]() |
Looks like a head to block locating dowel. They can’t get out whilst engine is assembled though
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
For a peace of mind I would compare with TYT500020 or LR004348 Puma 110" SW
Ambo_Chris Member Since: 01 Dec 2021 Location: South West Posts: 32 ![]() ![]() ![]() |
Fantastic, good news I guess? 2013 Baltic Blue 110 Utility Station Wagon XS 2.2
2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2472 ![]() ![]() |
Unless someone has had the engine apart then I suspect the dowel has been in their from assembly. Hopefully it’s not missing from the engine, just a “spare “ that the ford kindly left in your sump in case you ever needed it.
I was not aware the oil sump had a magnet. Puma 110" SW
Sorry , having a brain fade today, it’s the gearbox that has a magnet fitted, not the engine sump.
It is a replacement engine done by the previous owner. Not sure of the source but it is a later engine with the screw on type oil filter rather than the insert type. 2013 Baltic Blue 110 Utility Station Wagon XS 2.2 2000 Beige Discovery 2 Td5 GS (Long gone) 1994 Red (various) 90 300tdi CSW (Long gone) |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
Did you fit the magnet at that last oil change 2000 miles ago? Strange for that dowel to appear now and not then > 110 XS Double Cab
No I’m pretty sure it was already on there and obviously there was nothing on there then. 2013 Baltic Blue 110 Utility Station Wagon XS 2.2
