Home > Puma (Tdci) > Rad cold after coolant flush
Ad-doublecab
United Kingdom 1995 Defender 110 300 Tdi DCPU Loire Blue
Hi guys,
So I recently fitted a new rad and thermostat and heater matrix on my 2.4 tdci filled up with coolant bleed the air out and the next day the coolant had dropped slight so topped it back up to the level
Took it for a drive around 8 miles but the rad isn’t getting hot getting hot air from heater but the rad still cold?
Am I not driving long enough for it to get hot or does it sound like a air lock? (Was around 30-40 min drive)
Post #986560 23rd Mar 2023 7:26pm
Dinnu
Sounds like engine not yet reached full operating temperature, so thermostat still closed. Especially if you were using the heater to warm the cabin, with low external temperatures, and not too much load on the engine. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #986568 23rd Mar 2023 7:57pm
Ad-doublecab
Thanks for replying I’ll take it for a longer drive with heaters off!
Post #986576 23rd Mar 2023 8:19pm
You want more like a 20 mile round trip and with the heaters off, depends on ambient temperature but it can take a while to get up to temperature.
Usually a couple of miles starts warming up, about 4 miles should be up to temperature but to fully heat up to maximum more than that.
Did you follow the bleed process of the workshop manual? _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #986578 23rd Mar 2023 8:40pm
Ad-doublecab
Thanks Steve, I’ll take it for a longer drive only thing I didn’t do was disconnect the oil thermostat coolant hose 😬
Post #986584 23rd Mar 2023 9:13pm
Ad-doublecab
Update
So I took it for a longer drive today 50 miles in total with the heater off the car was cutting in and out of power then died temp was half way, heater on alway is very hot and but drives okay rad was cold when I got back engine running but when switched it off rad was hot on the top right hand corner 😕
Anyone has this issue before?
Post #987117 28th Mar 2023 4:17pm
pdv
Belgium 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
any news ? i have exactly the same problem.
thanks
Post #1037852 19th Jun 2024 10:50am
Ad-doublecab
I put a new rad, new stat and was still the same then changed the heater control valve and that fixed it check your valve before replacing anything else
Post #1037858 19th Jun 2024 11:23am
MK
Did you fit one of those low temp thermostat? Puma 110" SW
Post #1037868 19th Jun 2024 12:55pm
Ad-doublecab
Started off with a normal one second one I fitted was the low temp stat
Post #1037869 19th Jun 2024 1:08pm
MK
I am switching back to the original one asap. And I´ll keep the oil cooler thermsotat off though. Puma 110" SW
Post #1037870 19th Jun 2024 1:13pm
pdv
hi all
my new OEM thermostat was totally faulty ( not opening) and the old one didnt open all the way, so after 2 new thermostats everything is back to normal.
original 86° stat fitted now that solved everything. Bow down Bow down Bow down
cheers T.
Post #1038503 26th Jun 2024 7:17pm
hornet
Thank you very much for your feedback!
Post #1038533 27th Jun 2024 8:52am
