![]() | Home > Td5 > Td5 2003 starting issue |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6045 ![]() ![]() |
It sounds like the solenoid on the starter.
If so you can rebuild solenoid, get stater off and get it rebuilt, or fit new starter. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21015 ![]() ![]() |
Check the grounding points and battery clamps are tight and clean, you’d be surprised how common these issues are especially the transmission connection and it’s not always the Starter.
Worth checking just in case first. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
roche1800 Member Since: 07 Apr 2020 Location: derbyshire Posts: 439 ![]() |
So I have inspected earthing and undone and cleaned terminals on motor and nothing.
Removed last night and here are photos inside solenoid with signs of wear …. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 178 ![]() ![]() ![]() |
I fitted this kit about 4 years ago, no problems since. There is a bolt that is a pain in the backside to get out, other that that, not a bad job.
https://x8r.co.uk/land-rover-discovery-td5...r-kit.html |
Cheers, fitted the refurb kit and the click is way better. Sadly done a bench test and the cog shoots out but doesn’t spin
