![]() | Home > Puma (Tdci) > MY2011/2012 Recall Action P047/048 Front Axle Case |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 998 ![]() ![]() ![]() |
Ahh... The old Flying Coffin..
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18024 ![]() ![]() ![]() |
No, I doubt that this info is actually available anywhere, although JLR will know how many have been reported to them (and will protect the information like no other). I am aware through this forum and one or two other sources of about a dozen flange weld failures of this type, including at least two outside the recall range, all of MIG-welded axles. I have not heard of any weld failures of friction-welded cases, although I am aware of one or two friction-welded cases that have split along the longitudinal weld (not the flange weld) on 130" cherry-pickers. Overall I suspect that the number of failures is small compared to the number of Defenders with potentially dodgy welds on the roads, but one failure is one too many. The catch brackets seem to work, and there is evidence of this (there is at least one reported failure on here after the brackets have been fitted and they worked exactly as designed) - in fact I have the brackets fitted to my friction-welded axle simply for peace of mind. I don't for a moment think that walking away from a vehicle simply because it hasn't had the brackets fitted is proportional or necessary, but if I was buying such a vehicle I'd not only pay particular attention to the current state of the axle but also I'd fit the brackets as a matter of priority. |
Its more a case of the inconvenience of trying to fight with JLR for any form of recompense and then having to foot the bill and source a new axle.
Obviously this would only be the the case if you survived the end of the axle detaching in the first place... Jim |
I think that it is unlikely you would even know that the weld had cracked with the brackets fitted unless you notice the tell-tale oil leak. The brackets will prevent the flange detaching from the axle, and it is extremely unlikely that any difference in handling would be noticeable. Eventually however, if you don't spot the leak, most of the axle oil will leak out and one day the diff will break and possibly seize the axle, but that is going to happen anyway one day since they all do in the end, and is only a matter of time on a 110 or 130 with any type of axle case. If the axle is not fitted with catch brackets and the weld fails it is an entirely different situation, and I cannot really understand how it is that none of the incidents we know about yet have resulted in a fatality, so far everyone has been incredibly lucky (or I suppose hasn't lived to report the incident). It is an extremely dangerous fault and it is still shocking that JLR has been and continues to be as nonchalant about it as it has. |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1359 ![]() ![]() ![]() |
I think this is very much a lawyer approach to life, standing in the witness box etc. If you want to avoid the risk of your children getting injured and die, don't take them with you in your defender period. By modern standards is a death trap "even if you deem it a small risk is a big call", nevermind the axle issue - which is just one of the many safety issues. Then you can say to your wife: "well its a good thing they were not in our defender when the accident happened." |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2529 ![]() ![]() |
It’s not a lawyer based approach, it’s a statistical based approach, with an element of Darwinism
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8474 ![]() ![]() ![]() |
Are lo ger swivel hous8ng bolts used for this mod? Cheers
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3642 ![]() ![]() ![]() |
If your question is if the lower swivel ball bolts are used....
Its a yes and a no at the same time. The swivel ball bolts are not disturbed to install or remove the catch brackets, but the catch brackets pit over and in the lower 3 bolt heads for better locking. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Sorry is was are the longer swivel to a axle bolts needed. But the answer must be no as I doubt they would fit in. Cheers
The answer is no, not required. The only parts required are the brackets themselves (unless the two bolts holding the radius arms to the axles on each side are in such poor condition that they cannot be reused, which which case your vehicle is already in a dangerous condition). These are the only fittings which need to be disturbed during the fitting of the brackets.
Cheers. Cheers
Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589 ![]() ![]() ![]() |
Having received m'y "invitation" from JLR a few weeks ago, I like this description of a "worst case scénario" with brackets mounted. The welds do look great (no corrosion, impurity, cracks, bad properties, etc.) they're flush and smooth (december 2012) But I do not have thé equipment for professional scans. I tow a sail boat (3.5 tons) sometimes. So I'm just wondering if those little brackets really do fit flush?? Even small mouvements were counter productive and lead to loss of stability and control. Are thèse brackets pre-tensioned ? |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
Boeing to JLR "We are having a little bother with some of our planes and we were wondering if you could suggest a quick fix for us." 1982 88" 2.25 diesel
[quote="Julie"]
I had JLR install my brackets in the latest recall update so I do not know how much of a gap, if any remains between the brackets and the radius arm brackets when they are offered to the axle. However, when I view mine, there seems to be no gap between the brackets and the swivel bolts. Given that there is only 1 reported failure of an axle with brackets might suggest that the brackets are pulling on the swivels, but this is more sort of a guess. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
