Home > Puma (Tdci) > EGR Blanking Plate Install
Page 2 of 2 <12
Aha, I had noticed that your location was "South West" but had completely failed to notice the tricolour - I thought you were GB.
Now I understand!
I found that my engine ran perceptibly better once the EGR was disabled, and would hate to be without the map, but I understand your points. Thumbs Up
Post #464597 19th Oct 2015 11:21am
K9F
^Same mistake I made. Embarassed Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #464599 19th Oct 2015 11:32am
You have to remember with a remap the fuelling is also much more efficient so I can see it balancing out.
There will also be lots of fluctuation on a vehicle like a Defender for various readings and I wouldn't mind betting nearly all would read differently.
One of the biggest problems with it in my opinion is the fact that it is not fit for purpose in my opinion.
If it does have to be replaced regularly that's fine but if so at least make it relatively cheap and easy access.
When they cause faults I would imagine you'd be creating more emissions as your getting no performance.
There is definitely an increase in MPG also which should balance out any possible increases emmissions wise.
But then who am I, the geniuses designed it and the we have to pay for the damned things every year or two.
Post #464690 19th Oct 2015 4:02pm
Bergos
Portugal 2007 Defender 110 Puma 2.4 HT Keswick Green
One question - is it possible to insert the blanking plate (before the EGR cooler) without removing the whole exhaust manifold?
Please, say yes Smile
K9F wrote:
Here you go! Thumbs Up
AndrewS wrote:
Here is a picture of what you are blanking off
Wider view
Now I have seen the configuration of the holes in the tube TBH I don't think there will be much difference between drilling a 5mm � hole or a 10mm � hole. I have drilled my blanking plate out to 19mm �
 Bergos
LR Defender 110 HT 2007 (2.4 Puma)
https://www.facebook.com/LR.Wanderlust/
Post #709678 29th May 2018 12:35am
Cupboard
Some blanking plates have little hooks rather than the rings and they are possible to fit just by loosening the bolts.
Post #709690 29th May 2018 9:05am
Bergos
Thanks. Mine has holes but I can cut it.
What if I leave the exhaust manifold in place and undo the nuts on EGR and the cooler? Is it possible to put a plate with holes like this? Bergos
Post #709746 29th May 2018 3:00pm
Johan H
Finland
Hello,
I'm about to install a blanking plate on my -08 Puma, but was a bit confused trying to locate the EGR-unit itself. I suppose it is on the non-turbo side of the engine? Is it on the front or the rear end of the engine block? I have been looking at the pictures above, but despite that cannot locate the unit in the engine bay Confused Embarassed
Will the blanking plate only go on one end of the EGR-valve, or is it possible to fit it on the wrong end? Or is there any difference at all on which side of the valve the plate is installed?
Sorry for the daft questions!
Cheers,
Johan
Post #765609 27th Mar 2019 9:52am
Caterham
if you look at the last but one photo you can see the turbo heat shield.
mine install at the other end of the egr cool (which is the pipe with the soot and many small holes)
I see as it makes much difference as to where it's closed really. the one above is done towards back of engine on turbo side
Thumbs Up
Post #765611 27th Mar 2019 10:06am
hank
Post #765614 27th Mar 2019 10:35am
Naycrx
Good Afternoon,
What is a Partial EGR Blank? And what are the Benefits?
Eventually we would like a remap with egr mapped out...... but for now can I put a blank in there? My understanding is of I put a 5mm hole in the centre it won't throw the Engine light on ? Is that correct?
Post #1035417 22nd May 2024 4:16pm
andy63
I'm going to try and explain my thoughts on what you call a partial blank.. Ie a blanking plate with a small hole..
To me it's really just a bit of a fudge.. To stop fault codes been generated.. It may stop the full flow of exhaust gases through the valve while allowing the map sensor to still confirm to the ecu that the egr valve is functioning.. It may help prolong the build up of carbon etc but lost on me..
As I said a bit of a fudge and in my view a waste of time.. Either get it stopped or allow it to operate as it should..
That's my take on it.. Others may have a different view🤔
Post #1035485 23rd May 2024 2:31pm
Page 2 of 2 <12
