![]() | Home > Td5 > Air con condensor supplier |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239 ![]() ![]() ![]() |
Yeah more than enough space. Also a fraction of the cost of the oem replacement. |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
Hopefully in the next 3 weeks for the first production batch. IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 551 ![]() ![]() ![]() |
@porny, can the condenser be bought with a frame, i'm installing AC in my defender
Also i'm looking for the M57 radiator and intercooler you do, tried ringing last week, whats the best time to call Shane |
robk Member Since: 30 Dec 2015 Location: Zeist Posts: 12 ![]() ![]() ![]() |
Hi Forum
This is how I solved it eventually. Using the similar condensor as bankz5152, which is wrongfully labeled by Autodoc as LR025985, but was really cheap (around €125) plus adding an Aliexpress 15 inch fan for around €30. A significant difference with the original Defender condensor (which is out off stock anyway) for £ 1,127. The tube extension is done with ordinary 12 mm water tubing en was tested by my local garage up to 20 bar 😀. To be honest he said he had never seen this before.... The A/C is now working better then before due to the larger condensor. ![]() Click image to enlarge ![]() Click image to enlarge Thanks for the 'out of the box' idea! KR Rob |
