Home > Td5 > Air con condensor supplier
Page 2 of 2 <12
Zed
Porny wrote:
I might be able to throw another option into the mix very soon....
Not going to be cheaper than some of the current options, but is a much more efficient design, using a much more modern core design... and won't start falling apart after 12 months.
Currently undergoing sign off testing.
With single fan or twin fan mounts - and reuses the original frame (and fan if going single).
This is a high quality all aluminium set up.
There has been a few changes to design - photos are original prototype.
This looks great. When will it be available to buy? WARNING.
Post #1035146 19th May 2024 10:42am
bankz5152
robk wrote:
Ow, indeed looks like the A/C grill leaves enough room at the bottom for the higher condenser. Great!
@porny, I would still be interested in your route of repairing the (original) condenser. Can you please share the make and model you have used to replace the condenser only.
Best regards
Rob
Yeah more than enough space. Also a fraction of the cost of the oem replacement.
Post #1035147 19th May 2024 11:26am
Porny
Site Sponsor
Hopefully in the next 3 weeks for the first production batch. IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #1035178 19th May 2024 10:13pm
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
@porny, can the condenser be bought with a frame, i'm installing AC in my defender
Also i'm looking for the M57 radiator and intercooler you do, tried ringing last week, whats the best time to call
Shane
Post #1035200 20th May 2024 10:18am
robk
Netherlands 2002 Defender 110 Td5 SW Epsom Green
Hi Forum
This is how I solved it eventually. Using the similar condensor as bankz5152, which is wrongfully labeled by Autodoc as LR025985, but was really cheap (around €125) plus adding an Aliexpress 15 inch fan for around €30. A significant difference with the original Defender condensor (which is out off stock anyway) for £ 1,127.
The tube extension is done with ordinary 12 mm water tubing en was tested by my local garage up to 20 bar 😀. To be honest he said he had never seen this before....
The A/C is now working better then before due to the larger condensor.
Thanks for the 'out of the box' idea!
KR Rob
Post #1039008 3rd Jul 2024 10:10am
Page 2 of 2 <12
