![]() | Home > Puma (Tdci) > African oil!! |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512
Will just any 5W-30 work? From a good source of course.
Any? NO. Any 5W30 meeting Acea A5/B5 hopefully. Or Acea C2,C3, A3/B4 (if fuel is high in sulphur). As well, Mobil 1 0W40 is aceptable as it shears down to 5W30 quite fast. I would not use Acea C1, C4 etc or any oil formulated for petrol engines. Puma 110" SW ............................................................. Earth first. Other planets later |
| HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 831
Thanks MK.
Will keep an eye out for these. |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21045
https://www.opieoils.co.uk/p-162109-castro...tid=263887
C1 isn’t for petrol, Diesel as mentioned in the link above. Which is what I’ve used above this time around. The above meets specs for Def 2.2 JLR approval, backwards compatible for 2.4’s as well. (I’ve used the C1 in my 2.4). Or for a 2.4 you can alternatively use: ACEA A1/B1, A5/B5 API SN/CF ILSAC GF4 Meets Ford WSS-M2C913-C Jaguar Land Rover engine oil specification ST JLR.03.5003 The alternatives just above maybe easier to source than C1. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| All times are GMT |
