Home > Puma (Tdci) > African oil!!
Page 2 of 2 <12
HardCharger
Thank you for the information, unfortunately these Ford rated oils are EXPENSIVE and difficult to find here (Manila, Philippines).
There are other oils from petrol stations like Shell and some "cheaper" brands in 5W-30 but unsure if they can be used on 2.4 and 2.2 Pumas. The 2.2 Pumas in these parts thankfully do not have a DPF unless they were imported from a country that required them.
Will just any 5W-30 work? From a good source of course.
Post #1032872 26th Apr 2024 3:33am
MK
Any? NO. Any 5W30 meeting Acea A5/B5 hopefully. Or Acea C2,C3, A3/B4 (if fuel is high in sulphur). As well, Mobil 1 0W40 is aceptable as it shears down to 5W30 quite fast.
I would not use Acea C1, C4 etc or any oil formulated for petrol engines. Puma 110" SW
Post #1033000 27th Apr 2024 12:01am
HardCharger
Thanks MK.
Will keep an eye out for these.
Post #1033213 29th Apr 2024 8:35am
https://www.opieoils.co.uk/p-162109-castro...tid=263887
C1 isn’t for petrol, Diesel as mentioned in the link above.
Which is what I’ve used above this time around.
The above meets specs for Def 2.2 JLR approval, backwards compatible for 2.4’s as well.
(I’ve used the C1 in my 2.4).
Or for a 2.4 you can alternatively use:
ACEA A1/B1, A5/B5
API SN/CF
ILSAC GF4
Meets Ford WSS-M2C913-C
Jaguar Land Rover engine oil specification ST JLR.03.5003
The alternatives just above maybe easier to source than C1. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1033316 29th Apr 2024 8:53pm
Page 2 of 2 <12
