![]() | Home > Puma (Tdci) > Squeaky seat |
Short term, a tin of silicon spray on anything that moves(or does but shouldn't) or just strap a child in all the time, just take them out at feeding time
Doublecabdefender Member Since: 17 Jan 2008 Location: Norwich, Norfolk Posts: 61 ![]() ![]() ![]() |
Me too, same problem in my DC, its driving me mad. I have stripped out one seat so far but cannot find anything wrong. The squeak has now turned into a rattle - squeak. Will try to strip out the other two seats tonight. If I find anything I will let you know.
![]() ''I can resist everything except temptation. '' |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 ![]() ![]() ![]() |
Thanks both. I'll try the silicon on everything trick first and look forward to hearing what's found inside!!
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Check that the little square rubber pads affixed to the body have not moved, been lost where the seat body meets the tub.
Thanks, I did suspect that at one stage as the rubber had separated from its sticky tape. I put it back together and it's not moved since so I'm not sure.... |
