Home > Puma (Tdci) > Squeaky seat
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
Squeaky seat
I have a squeaking rear seat, the "60" split part behind the driver. Only seems to do it when they're in the normal position and also seem ok if someone is sat on it. I can't for the life of me work it out when I'm driving and the wife and kids have lost the will to live trying to help me.... I've greased the latch on the floor and that made no difference so I'm guessing it may be something internal.
Any other ideas and are they easy to get into if I need to carry out some surgery?
Post #103255 29th Nov 2011 11:06am
JWL
Short term, a tin of silicon spray on anything that moves(or does but shouldn't) or just strap a child in all the time, just take them out at feeding time Whistle
Post #103262 29th Nov 2011 11:18am
Doublecabdefender
United Kingdom 2012 Defender 110 Puma 2.2 XS DCPU Orkney Grey
Me too, same problem in my DC, its driving me mad. I have stripped out one seat so far but cannot find anything wrong. The squeak has now turned into a rattle - squeak. Will try to strip out the other two seats tonight. If I find anything I will let you know. Mad 2012 Defender 110 DCPU XS 2.2 Puma Orkney Grey
''I can resist everything except temptation. ''
Post #103267 29th Nov 2011 12:13pm
scotty38
Thanks both. I'll try the silicon on everything trick first and look forward to hearing what's found inside!!
Post #103268 29th Nov 2011 12:14pm
Lorryman100
Check that the little square rubber pads affixed to the body have not moved, been lost where the seat body meets the tub.
Post #103280 29th Nov 2011 1:19pm
scotty38
Thanks, I did suspect that at one stage as the rubber had separated from its sticky tape. I put it back together and it's not moved since so I'm not sure....
Post #103283 29th Nov 2011 1:27pm
