Home > Technical > fault reader |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1114 |
which fault reader are you all using? man for td5
28th Nov 2011 8:50pm |
Search reveals....
Happy reading....! http://www.defender2.net/forum/topic9211.html?highlight=nanocom http://www.defender2.net/forum/topic8087.html?highlight=nanocom http://www.defender2.net/forum/topic9017.html?highlight=scangauge http://www.defender2.net/forum/topic6588.html?highlight=scangauge http://www.defender2.net/forum/topic5127.html?highlight=blackbox http://www.defender2.net/forum/topic3385.html?highlight=blackbox If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
28th Nov 2011 9:39pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
The Nanocom is a good one
http://bellautoservices.co.uk/nanocom/nanocom-evolution/ Pete |
28th Nov 2011 11:05pm |
is the Faultmate MSV-2 a bit over kill for the td5 ?
29th Nov 2011 1:12pm |
29th Nov 2011 10:11pm |
still not sure which one,they seem to do the same things but in different ways
could you use the faultmate MSV-2 to its full use or would the nanocom be better for td5 defender.? any more input into this would be a help. |
29th Dec 2011 7:13pm |
The BAS remap interface is not what you need for diagnostics though it does program map files.
The best tool is the MSV2 which will program map files and do all diagnostics in most cases is vin lockedunless ordersin MV form, The nanocom with the same functions in a hand help color touch screen package and is not vin locked. If you want mobile standalone use on any TD5 engine diagnostic tool then you need a Nanocom Evo. {ete |
29th Dec 2011 8:36pm |
thanks how much are the nanocom Evo |
29th Dec 2011 8:56pm |
anyone near gloucester with to have a look at.
29th Dec 2011 8:59pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6266 |
did a search and this is what I found......
I see mention above of a the remap device also reads basic fault codes.... can someone tell me what faults codes are basic and what fault codes over and above this a nono com would pick up. also would the nano com pick up ALL fault codes? looking for something that will function on a 2.4 puma and disco 3 (2.7 v6) many thanks. |
21st Jun 2013 8:12am |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Do you think you be happy with a fault reader? or is it just going to cause you a load of stress worrying about fault codes and the imminent self destruction of your engine. PM lorryman he may be kind enough to explain fault codes to you. Original Member Pie n Pea Club.
110 HCPU Tipper |
21st Jun 2013 9:12am |
My own worst enemy. Engine is going great now. Still not so sure of transmission / hand brake.....i'm getting there. Fault reader is more for my dad. |
21st Jun 2013 9:23am |
