Home > General & Technical (L663) > Fault after enabling dynamic with G4
Looneyfitter
Hi can anyone tell me why I have a yellow i in a circle on the dash? I also had a fault come up saying start stop switch fault whilst uploading the ccf.
Lastly, using the terrain selector, I can't select the wavy road to apply dynamic settings?
Many thanks.
Post #1032260 20th Apr 2024 8:39pm
Looneyfitter
These are the 3 changes I made. Cheers.
Post #1032261 20th Apr 2024 8:42pm
DefenderMidlands
Dynamic Mode settings
EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode"
EUCD-245 Dynamic-I
Standard: Dynamic-i Not Fitted
Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen
MultiCAN-562 DynamicProgMode
Standard: Not available for selection
Changed to: Available for selection without timeout
Other possible value: Available for selection with timeout
MultiCAN-605 ConfigDynamicMode
Standard: Not Fitted
Changed to: Fitted
MultiCAN-777 Ter Dyn Select In FCPB
Standard: Control interface not available in FCPB
Changed to: Rotary used for selection within touch screen
EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode" MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1032266 20th Apr 2024 9:43pm
Looneyfitter
Ah OK mate thanks. So there's more codes to address?
Post #1032270 20th Apr 2024 10:23pm
DefenderMidlands
I think you may of only half enabled it. Need to reboot pivi afterwards and lock and leave car to sleep 15mins min MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1032271 20th Apr 2024 10:41pm
Defendit..
Netherlands
I also set: Multican 682 DynamicLiteMode to Available for selection whitout timeout. No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1032288 21st Apr 2024 8:36am
Looneyfitter
OK so added the missing codes this morning. I can now select terrain response but I still have the i on the dash.
I had a message pop up on the screen saying start/stop button fault detected.
I have run fault finding and this is the only fault I have?
I did enable WiFi hot-spot too yesterday. Wondering if. It could be that?
Post #1032295 21st Apr 2024 10:35am
mmbanf
Italy
hi, this error doesn't seem indicative of a problem on bcm,
Does the error remain even after the machine sleeps?
personally I would restore the original configuration, then possibly try to make one change at a time.
Marco
Post #1032341 21st Apr 2024 8:32pm
Retroanaconda
All the changes I have applied have taken several ignition and sleep cycles to start work properly and all have created error messages to begin with. I think it takes a day or two for all the ECUs to learn the new CCF and before that happens it can generate errors.
Post #1032344 21st Apr 2024 8:42pm
Looneyfitter
Thanks for the input guys. All is OK now. After a few resets it went away. The i with a circle was because I was low on fuel lol
Post #1032358 21st Apr 2024 10:00pm
