Home > Puma (Tdci) > Rear Diff
Naycrx
Rear Diff
Rear Diff, looks to have a very slight oil leak..... I think... can I put some of the gear oil Leak Stop fluid in with an oil change ?
Post #1032004 18th Apr 2024 1:05pm
geobloke
Where is the leak coming from: Fill plug, drain plug, diff flange or from between the diff and axle housing?
Post #1032033 18th Apr 2024 5:34pm
Naycrx
Think its the flange.... Where it comes out to the prop...... Just noticed the other day looked damp, i have wiped it and hasn't really leaked anymore
Post #1032037 18th Apr 2024 5:48pm
landy andy
Check your breather is clear.
Post #1032039 18th Apr 2024 5:56pm
Naycrx
Hi,
Yes I have done that..... I removed it and blew down all seems OK.... noticed when I removed the pipe, the pipe has a 90' curve and just pushes in ? Is that right no connection or anything
Post #1032040 18th Apr 2024 6:00pm
landy andy
It should push into a pushfit fitting, and require the collar to be held in as pipe is pulled out.
Post #1032042 18th Apr 2024 6:03pm
Naycrx
Hmmm..... I would say its been taken off then , could anybody tell me the thread and pipe size, ?
Many thanks again for help
Post #1032044 18th Apr 2024 6:08pm
Naycrx
M12 with a 6mm pipe ??
Post #1032045 18th Apr 2024 6:10pm
landy andy
The original fitting is a brass item that is pushed into the axle hole.
It’s explained here.
https://gwynlewis4x4.co.uk/product/land-ro...-fittings/
Post #1032046 18th Apr 2024 6:14pm
Check the prop UJ’s right away, especially the one nearest the diff.
If they fail, or a bearing cup has failed, that can in turn cause the diff nose pinion oil seal to become oval and thus leak.
And if oil can leak out, water can get in so until fixed try and avoid significant amounts of water such as Fords, river crossings, deep water etc.
This is based on presumption, and bear in mind the UJ’s can be difficult to notice their failure unless unbolted.
Mine went though servicing and MOT unnoticed at the time, I checked by taking it off and it was obvious, not so easy to tell whist bolted in situ though.
Are the nipple / zerks there? When were they last greased out of interest?
Thumbs Up ___\⭐️Lone|Star|State/___
____\We|Will|Win/___[/size]
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1032048 18th Apr 2024 6:23pm
Naycrx
Yes we have the original brass one after uncovering the dirt.....I have just got a new fitting and pipe....I'll fit that see if its better
Post #1032049 18th Apr 2024 6:24pm
