![]() | Home > Puma (Tdci) > Rear Diff |
Where is the leak coming from: Fill plug, drain plug, diff flange or from between the diff and axle housing?
Naycrx Member Since: 11 Oct 2023 Location: Nottinghamshire Posts: 166 ![]() ![]() |
Think its the flange.... Where it comes out to the prop...... Just noticed the other day looked damp, i have wiped it and hasn't really leaked anymore
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5979 ![]() ![]() |
Check your breather is clear.
Hi,
Yes I have done that..... I removed it and blew down all seems OK.... noticed when I removed the pipe, the pipe has a 90' curve and just pushes in ? Is that right no connection or anything |
It should push into a pushfit fitting, and require the collar to be held in as pipe is pulled out.
Hmmm..... I would say its been taken off then , could anybody tell me the thread and pipe size, ?
Many thanks again for help |
M12 with a 6mm pipe ??
The original fitting is a brass item that is pushed into the axle hole.
It’s explained here. https://gwynlewis4x4.co.uk/product/land-ro...-fittings/ |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20912 ![]() ![]() |
Check the prop UJ’s right away, especially the one nearest the diff.
If they fail, or a bearing cup has failed, that can in turn cause the diff nose pinion oil seal to become oval and thus leak. And if oil can leak out, water can get in so until fixed try and avoid significant amounts of water such as Fords, river crossings, deep water etc. This is based on presumption, and bear in mind the UJ’s can be difficult to notice their failure unless unbolted. Mine went though servicing and MOT unnoticed at the time, I checked by taking it off and it was obvious, not so easy to tell whist bolted in situ though. Are the nipple / zerks there? When were they last greased out of interest? ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Yes we have the original brass one after uncovering the dirt.....I have just got a new fitting and pipe....I'll fit that see if its better
