Home > Puma (Tdci) > Transit clutch and Output shaft change, couple of questions.
Page 1 of 4 1234>
Waka56
Germany
Hi everyone,
I have a huge backlash (probably from every part possible) and my clutch is starting to make some noise so I decided I would change clutch and outputshaft... Myself..
I am not a mecanic but I have always been servicing my cars (At least the basics) myself..
The most I've done was a timing belt change on my ex Alfa, but I feel like taking the gearbox out is on another level.. I will have a good few days (5-6) to do it so I can take my time, but I would like to know what can be expected to go wrong (Exhaust bolts to change, anything involved in taking the gear box out with the car on the ground) so that I am more or less ready.
I will go with the transit 4x4 clutch, I also want to change the Spigot bearing. Because the car is new to me and I have no idea how is the alignment between the GBox and the TBox I want to avoid the One piece LOF outputshaft and go with the basic LOF one so that nothing else gets damaged in case of a real bad alignment. If this does not make sense, let me know, I can always change my mind.
So, so far here is what I got in term of material needed.
For the Clutch:
- Clutch Sachs 3000 950 727
- Master cylinder 6284 600 602
- Central slave cylinder LPR 3279 (LR068979) *Any brands recommended?*
- Clutch control valve LR068982
- Slave cylinder adapter LR068981
- Spigot bearing LR004390
- New bolts URC000030
For the Output shaft:
- TDCI Output shaft MT82 (LOF)
- Oil Seal LR0058800
Transfert box seal: ICV100000.G
I also need a few new tools on top of the basic ones I have (feel free to add some more):
-3 Legged puller, one for the Spigot (This type https://www.ebay.com.au/itm/383575022014) and one for the output shaft (Like this one: https://www.uktools.com/sp-10032000-self-g...150mm.html)
-Slide hammer? (Probably no need because of the puller)
-9/16in slim headed propshaft socket?
I´ve seen people using 52mm socket to push the bearing in place, any other methods?
I know that the Gbox and TBox assembly is really heavy, so I intend to somehow build some support with a jack or 2, happy to hear from people that done it on the ground. Also happy to hear if it really should not be done.
I will update this post with the new ideas, I appreciate any help. Making my Defender great again. (Or trying to at least xD)
Post #1031395 13th Apr 2024 11:02am
htb2
Wales
I have always extracted spigot bushes with the old grease method, never done a transit one mind, all mine have been TD5 and prior era. Fill up behind the spigot bush with grease, find a nice close fitting socket or round bar that fits into the bore of the bush, tap in socket till bush comes out, may have to refill with grease a couple of times till its out, you are basically pushing bush out with hydraulic pressure. It can be a tad messy, but not had one I could not extract so far.
Post #1031398 13th Apr 2024 12:07pm
That method will not work with the TDCi spigot bearing due to the design of the bearing assembly, which is the reason so many folk including "professionals" end up destroying the crankshaft.
You may be able to extract it with a puller such as that in the OP's post but a purpose-made puller such as that from SP is vastly better.
https://sykes-pickavant.com/products/09584...ction-info
https://lofclutches.com/shop/clutches/defe...pickavant/
Post #1031404 13th Apr 2024 12:43pm
htb2
Wales
Thanks Blackwolf for the clarification as said all my vehicles are TD5 or earlier.
Post #1031406 13th Apr 2024 12:50pm
Waka56
Germany
I have seen that you've done the job a couple of times, did you do it on the ground? Engine crane needed? Making my Defender great again. (Or trying to at least xD)
Post #1031408 13th Apr 2024 1:04pm
On the ground, no crane but using a transmission trolley jack.
Post #1031424 13th Apr 2024 4:10pm
Dinnu
Since you are replacing the adaptor shaft (unsure why you do not consider Ashcroft’s - no affiliation). It will be far easier to take out the transfer box first, and then the gearbox in 2 separate units.
I have removed transfer boxes without lifting a wheel off the ground. Not removed a gearbox…yet!
Be aware that there are different lengths of bolts that bolt the transfer case to the adapter housing. Get the wrong one in the wrong hole, and it will jam or wreck the transfer case. On mine, I have replaced the bolts with studs, glued into the case. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1031426 13th Apr 2024 4:14pm
Waka56
Germany
Thanks, that's what I was thinking to. Did you have the car on jack stands? Making my Defender great again. (Or trying to at least xD)
Post #1031430 13th Apr 2024 5:01pm
Waka56
Germany
Okey, I'll deffo write down what goes where and take pictures. For the adaptor shaft, I wanted to keep a weaker link and see how it goes (might also go for original). The car as 200kkm with a severe backlash, I don't know if it is original or just a pretty bad alignment.. Want to drive it myself 30-40kkm see how it goes.
Edit: I see that a lot of people with shaft going bad after 25kkm swapping to the stronger version. Did new problems arised while upgrading the shaft? (In the Gbox or Tbox which would mean even costlyer problems) Making my Defender great again. (Or trying to at least xD)
Post #1031431 13th Apr 2024 5:06pm
Dinnu
The Ashcroft adaptor shaft is not stronger, it just allows some oil to leak into the otherwise dry splines. The oil is then contained by a cover. Infact Ashcroft used to just modify the original shafts, and make the cover. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1031437 13th Apr 2024 5:53pm
Waka56
Germany
Yup, went thru a whole thread and came to just what you say Laughing
Thanks Smile
The ashcroft uses the oil from the Gbox right? Does it make it fiddlier to fit/more prone to oil leaks? Making my Defender great again. (Or trying to at least xD)
Post #1031442 13th Apr 2024 6:07pm
TexasRover
Quite amazing that Land Rover managed to make the exact same mistake twice. You would think such a predictably design error would be in their gearbox design 101
Post #1031443 13th Apr 2024 6:11pm
No, on its wheels, but you have to raise it to get the MT82 out from under the chassis. If you don't need the box out from underneath you don't need to raise it. I just used a high-lift under the rock slider whilst I dragged the box out.
Post #1031448 13th Apr 2024 7:17pm
Dinnu
Correct.
Fiddlier to fit? No, at least not in my opinion. Actually I think its a tad easier compared to the flimsy cover and the need to put a cable tie on the original design, especially if the adapter housing is still on the gearbox.
Prone to leak? Well there are 2 possible leak points. One is with double O ring on the cup, and a large x sectional o ring on the shaft. Mine has been there for almost 4 years and no sign of leakage.
Main problem with O rings is when they can get into a square profile, and stop sealing. But when that happens, I guess the O ring on the transfer case intermediate shaft would have also started to weep. So anyhow, its still a TC out. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1031452 13th Apr 2024 8:31pm
Waka56
Germany
Anything you'd do once the transfer case is down? Mine is most likely leaking a bit. Making my Defender great again. (Or trying to at least xD)
Post #1031505 14th Apr 2024 12:04pm
Page 1 of 4 1234>
