![]() | Home > General & Technical (L663) > Driving in muddy conditions |
| Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1326
Did you switch to low box with mud setting?
I have road based tyres and just recently have been amazed how the Defender pulls itself down muddy farm tracks…pulling trailer loads of logs. I don’t “ do anything” other than point it in the correct direction and touch the throttle. Even downhill it seems to have great control Clemmo |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3531
l didn't use low range
l have in the past selected "mud & ruts" and it did improve traction. l'll change the wheels over and see what difference it makes. |
Low range makes a huge difference
It won’t allow the wheels to spin simultaneously Tyres will help but once full of mud they take a lot to clear Try the tech..it’s 👍 Clemmo |
Will do! Never tried low range tbh
Looks like l've been doing it incorrectly. Still, at least the new tyres will look more "tough" lol |
As an aside..( and I know you are awaiting a new car) it pays to run in low once a month. Doing this ensures all the actuators work and do not seize. It’s the old use it or lose it syndrome |
| Mrburt Member Since: 04 Jan 2023 Location: Shropshire Posts: 41
Muddy fields are an interesting challenge.
Most folk think the mud & ruts program is the solution, this program allows the wheels to spin in order to find better grip beneath. This however can be your downfall if there is no better surface below and you end up just digging a hole for all four wheels. In this scenario grass gravel snow can be a better option. Muted throttle, moving off in second and a more proactive use of TC can provide a solution. Add in low range and tick over can get you moving without any throttle and minimal wheel speed. If you are towing them low range is your best friend in moving forward with minimal fuss. Of course all this is subject to tyre grip and the more specific off road tyres will be of benefit when it gets tough, but the cross climate tyres are very good and a fine compromise. The gold rule Tyres give you grip, drivetrain gives you traction. Hope this helps folks. |
[quote="Clemmo"]
As an aside..( and I know you are awaiting a new car) l did have a 110 Commercial on order but cancelled it due to the fact that the figures didn't work. l would get taxed on the sale price of my 90 and can't get the same deal on the new one. There was a govt scheme running when l got my 90 that meant l could claim 130% of the cost against tax. |
Thank you that's great advice. l still don't fully understand the various modes on the new one. |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3786
Did you get a landrover experience day when you made you purchase? They usually take you through all the features, and when you drive the course it is done on the latitude tyres and they cope well.
| martinf Member Since: 30 Nov 2020 Location: Sussex Posts: 107
One of the features that I find frustrating is the inability to select low range whilst on the move.
I remember my P38 Range Rover allowed this at low speed and I found it useful if the conditions deteriorated and I wanted to select low range without losing momentum. It would be easy to have the software prevent selection above a certain speed. |
Shout up if you need further. Always happy to assist. |
| Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 921
Low should let all 4 wheels spin else your 4wd system is broken.... But if you are spinning all 4 wheels at the same time, it is a lack of traction and fancy electronics are unlikely to solve it. |
Tyres will depend on the vehicle, they have lots of vehicles at the Experience centres. And when I went they most certainly didn't go through all the modes or explain how any of them worked. |
This is one of the huge downfalls of the electronic system, it is hugely complicated and you need to be an expert on not only the conditions, but each and every mode and how it works to know if it is the right one or not to use at the time. Even without the programmable TR2 you have what 15-20 different modes you could use. Old school vehicles are a lot easier to get it right as you'd only have a few setups to choose from. There are some good Youtube videos that show the differences between the TR modes that might be worth watching. Remember you need to manually turn off stability control for some modes too. As for your situation, low should help because you get more control and more wheel torque, I suspect the terrain system is also programmed slightly differently when in low vs the same mode in high. However if it is easily and freely spinning all the wheels on a relatively flat surface, it is more of a tyre issue. ?si=l2qejy44Qs0eEl0Y ?si=8LdpEXMI9bSC9NUn ?si=nQY3F7alPOAIZ9ow |
| All times are GMT |
