Home > General & Technical (L663) > Driving in muddy conditions
Page 1 of 3 123>
lightning
Three times recently l've found myself having to cross a muddy field towing our caravan and l have to say the standard Michelin Latitude tyres aren't great in these conditions.
ln fact l almost got stuck in the muddy car park field at Bakewell (not towing the 'van) all four wheels rotating helplessly. Although l did get out okay.
But they look to be essentially a road biased tyre.
l've just bought a set of new "take off" steel wheels with the Goodyear Wrangler Adventure tyres
The tread certainly looks more purposeful on these tyres.
I hope they do better towing our caravan out of a field. Has anyone had experience using these tyres in muddy off road conditions. Are they better? l hope so, having spent £550 on a set of five.
Although it's still a bargain for five new wheels with tyres, wheel nuts and centre caps.
Post #1030863 7th Apr 2024 6:15pm
Clemmo
Did you switch to low box with mud setting?
I have road based tyres and just recently have been amazed how the Defender pulls itself down muddy farm tracks…pulling trailer loads of logs.
I don’t “ do anything” other than point it in the correct direction and touch the throttle.
Even downhill it seems to have great control
Clemmo
Post #1030873 7th Apr 2024 6:40pm
lightning
l didn't use low range
l have in the past selected "mud & ruts" and it did improve traction. l'll change the wheels over and see what difference it makes.
Post #1030881 7th Apr 2024 7:54pm
Clemmo
Low range makes a huge difference
It won’t allow the wheels to spin simultaneously
Tyres will help but once full of mud they take a lot to clear
Try the tech..it’s 👍
Clemmo
Post #1030889 7th Apr 2024 8:37pm
lightning
Will do! Never tried low range tbh
Looks like l've been doing it incorrectly. Still, at least the new tyres will look more "tough" lol
Post #1030891 7th Apr 2024 8:42pm
Clemmo
Thumbs Up
As an aside..( and I know you are awaiting a new car) it pays to run in low once a month.
Doing this ensures all the actuators work and do not seize.
It’s the old use it or lose it syndrome
Post #1030892 7th Apr 2024 8:50pm
Mrburt
Muddy fields are an interesting challenge.
Most folk think the mud & ruts program is the solution, this program allows the wheels to spin in order to find better grip beneath. This however can be your downfall if there is no better surface below and you end up just digging a hole for all four wheels.
In this scenario grass gravel snow can be a better option. Muted throttle, moving off in second and a more proactive use of TC can provide a solution. Add in low range and tick over can get you moving without any throttle and minimal wheel speed.
If you are towing them low range is your best friend in moving forward with minimal fuss.
Of course all this is subject to tyre grip and the more specific off road tyres will be of benefit when it gets tough, but the cross climate tyres are very good and a fine compromise.
The gold rule
Tyres give you grip, drivetrain gives you traction.
Hope this helps folks.
Post #1030899 7th Apr 2024 9:54pm
lightning
[quote="Clemmo"]Thumbs Up
l did have a 110 Commercial on order but cancelled it due to the fact that the figures didn't work. l would get taxed on the sale price of my 90 and can't get the same deal on the new one.
There was a govt scheme running when l got my 90 that meant l could claim 130% of the cost against tax.
Post #1030903 7th Apr 2024 10:45pm
lightning
The gold rule
Thank you that's great advice. l still don't fully understand the various modes on the new one.
Post #1030904 7th Apr 2024 10:47pm
Co1
Did you get a landrover experience day when you made you purchase? They usually take you through all the features, and when you drive the course it is done on the latitude tyres and they cope well.
Post #1030910 8th Apr 2024 6:20am
martinf
One of the features that I find frustrating is the inability to select low range whilst on the move.
I remember my P38 Range Rover allowed this at low speed and I found it useful if the conditions deteriorated and I wanted to select low range without losing momentum.
It would be easy to have the software prevent selection above a certain speed.
Post #1030911 8th Apr 2024 7:38am
Mrburt
The gold rule
Shout up if you need further. Always happy to assist.
Post #1030916 8th Apr 2024 8:37am
Chicken Drumstick
Clemmo
Low should let all 4 wheels spin else your 4wd system is broken.... But if you are spinning all 4 wheels at the same time, it is a lack of traction and fancy electronics are unlikely to solve it.
Post #1030921 8th Apr 2024 9:15am
Chicken Drumstick
Tyres will depend on the vehicle, they have lots of vehicles at the Experience centres. And when I went they most certainly didn't go through all the modes or explain how any of them worked.
Post #1030924 8th Apr 2024 9:18am
Chicken Drumstick
This is one of the huge downfalls of the electronic system, it is hugely complicated and you need to be an expert on not only the conditions, but each and every mode and how it works to know if it is the right one or not to use at the time.
Even without the programmable TR2 you have what 15-20 different modes you could use. Old school vehicles are a lot easier to get it right as you'd only have a few setups to choose from.
There are some good Youtube videos that show the differences between the TR modes that might be worth watching. Remember you need to manually turn off stability control for some modes too.
As for your situation, low should help because you get more control and more wheel torque, I suspect the terrain system is also programmed slightly differently when in low vs the same mode in high. However if it is easily and freely spinning all the wheels on a relatively flat surface, it is more of a tyre issue.
?si=l2qejy44Qs0eEl0Y
?si=8LdpEXMI9bSC9NUn
?si=nQY3F7alPOAIZ9ow
Post #1030926 8th Apr 2024 9:33am
Page 1 of 3 123>
