Page 1367 of 1393 <123 ... 136613671368 ... 139113921393>
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Replaced the entire wiper system after mine siezed up, what a PITA, prehistoric design. Anyway, it’s done, along with an unrated optimill squirted which I was given.
Everything working, except the heater for some reason and when I switch the heated rear window on, the radio goes off. I guess I’ve disturbed an earth or some connectors so I’ll get on that tomorrow.
Post #1029940 31st Mar 2024 4:21pm
excossack
Replaced the drive belt with a new one. I think the squeak has now finally been cured. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1029945 31st Mar 2024 4:58pm
Steveww - The DIN cages are sharp too, many have been made more rigid and slimmer towards the locking aperture for that reason so they aren’t rattling.
But as I said they can have some sharp edges it be careful of as well<especially cheaper ones.
JoolsB - Ah yes, the wipers job is a big one. I had the joys of that last year. I am relieved it’s over and not a job that is often required to be done!
Excossack - Not too bad a job to do that one, they do make some noises.
I saw an interesting article the other day regarding alternator whine and noises via audio system.
(Which isn’t the issue you had I doubt, probably externally audible from itself.
Anyway, the belt was creating static charges, and that was being mirrored upstream with every revolution, and that was causing static electric charges, pulses upstream, and back up to the audible system.
I don’t know what vehicle it was or anything like that, but was interesting alll the Sam exit was in the States.
The guy had tried all sorts to try and find it, checked everything but a new serpentine belt sorted it out.
There wasn’t even any issue with the Alt, or any other component other that it was picking up static.
I suppose a RF choke or ferrite ring or clip may have been useful though.
Bearings can cause an issue too, but you never know hopefully that’s all good for you now. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1029953 31st Mar 2024 5:48pm
excossack
Thanks C90. Hopefully all solved now...Well until the next noise appears. Time will tell.
I will look into replacing the bearings in the pulleys. I think Geobloke has done this. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1029960 31st Mar 2024 6:16pm
M94PUMA
Avoiding the rain!
Window tints, leaking camshaft seal. New belt, tensioner, & idlers!
Post #1030223 2nd Apr 2024 5:18pm
Looks good. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1030238 2nd Apr 2024 6:15pm
Screbble
I agree with Steve - looks very good 👍
Can’t help but have wheel envy Mr. Green
Post #1030246 2nd Apr 2024 6:43pm
spudfan
Ireland
2.4 2011 Puma. Up for the test this morning. Pass.
 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1030464 4th Apr 2024 11:08am
Proper job. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1030510 4th Apr 2024 5:35pm
spudfan
Ireland
The series three being 42 years of age is exempt (40 years of age makes the exemption kick in) thank God! It used to be a nightmare with the braking imbalance. Failed once on a braking imbalance of 7%. Stopped great but the technology was saying there was an imbalance. 1982 88" 2.25 diesel
Post #1030512 4th Apr 2024 5:42pm
M94PUMA
Tidied up the rear end!
Crossmember cleaned down to metal and hit with buzzweld products. New mudflaps.
Internal gwyn Lewis mud shields.
All bolts replaced with stainless and tub to crossmember bolts used with correct grease to help prevent any corrosion.
Post #1030735 6th Apr 2024 5:36pm
Screbble
That looks splendid - a job very well done. I bet you feel a great sense of satisfaction.
Please cover your wheels up though as I keep getting very envious Thumbs Up
Post #1030743 6th Apr 2024 6:19pm
M94PUMA
Thank you! - Will have to censor them out in future Thumbs Up
Post #1030746 6th Apr 2024 6:26pm
CarMan
Very nice Thumbs Up Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #1030750 6th Apr 2024 6:32pm
80 mile round trip yesterday, never missed a beat.
Today took all the wheels off, greased the DM’s, all okay with those, none dry which is good and now re-lubed.
Checked brake pads life also, plenty there. Mr. Green
Noticed two of the pad springs on the front callipers, that one on each side out of each two per side, had managed to get into the brake pad aperture on the pins rather than sitting butt up against it. (It, being the pad and its aperture / hole).
Managed to carefully tease them out and they then sat against the area they should do butt up against the brake pad backing, they are there to push the pads away from the disc, though even when new they aren’t that strong then they aren’t meant to be.
With them like that, will mean the pads will sit close to the pad, perhaps a bit more than they should and add some drag and u wanted heat and thus a bit more fuel consumption for no good reason none of which would be great.
Perhaps might be a good idea to fit new calliper pins and springs. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1030858 7th Apr 2024 5:02pm
