Home > General & Technical (L663) > Does the ride height button mean it has air suspension?
Skimster
Looking at a used 2021 90 First Edition - the specs says it has "Multi-Link Rear Suspension w/Coil Springs, Short and Long Arm Front Suspension w/Coil" with "Gas-Pressurized Shock Absorbers",
but the pictures show it has the ride height adjustment button. Does that mean it has the air suspension?
Post #1030477 4th Apr 2024 12:42pm
J77
If it has buttons with up and down arrows next to the gear selector then it has the air suspension.
I might be wrong but I think air was standard on First Edtions 24MY 90 D250 HSE, Tasman Blue
Post #1030484 4th Apr 2024 1:23pm
Skimster
Thanks, J77.
With a bit of luck, I may be heading back to a Defender!
Post #1030487 4th Apr 2024 1:41pm
lightning
There's no option to change the ride height on the coil spring version and you don't get the "ride height" button.
So the one you are looking at will definitely have the air suspension.
Both are good, but the air suspension has a better ride quality and the ability to raise the ride height off road.
Post #1030488 4th Apr 2024 1:42pm
J77
Coil sprung cars
Post #1030495 4th Apr 2024 2:56pm
Skimster
Great. Thanks again, J77.
Somehow having that blank looks nicer Smile
Post #1030500 4th Apr 2024 4:36pm
lightning
Until you get to a heavily rutted track. Then you might be glad of the extra switch.
Post #1030667 5th Apr 2024 4:13pm
Moo
Ukraine
Or loading the car. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1030669 5th Apr 2024 4:25pm
lightning
l've had my coil sprung 90 Commercial loaded with a weeks camping gear including outboard motor, dinghy, bikes etc plus a caravan on the towbar and there's still no discernible change in the rear ride height
Post #1030698 6th Apr 2024 12:01am
walfy
Ilkove the air suspension, the comfort is worth it, but also when hooking trailers up, use the adjust buttons in the boot to lift the car to hook up. So much easier than winding the jockey wheel. Lazy?? Quite possibly but it makes life so much easier 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #1031821 17th Apr 2024 8:00am
