![]() | Home > General & Technical (L663) > Does the ride height button mean it has air suspension? |
| J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3525
If it has buttons with up and down arrows next to the gear selector then it has the air suspension.
I might be wrong but I think air was standard on First Edtions 24MY 90 D250 HSE, Tasman Blue |
| Skimster Member Since: 10 Jul 2021 Location: London Posts: 9
Thanks, J77.
With a bit of luck, I may be heading back to a Defender! |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3536
There's no option to change the ride height on the coil spring version and you don't get the "ride height" button.
So the one you are looking at will definitely have the air suspension. Both are good, but the air suspension has a better ride quality and the ability to raise the ride height off road. |
Coil sprung cars
Click image to enlarge 24MY 90 D250 HSE, Tasman Blue |
Great. Thanks again, J77.
Somehow having that blank looks nicer |
Until you get to a heavily rutted track. Then you might be glad of the extra switch.
| Moo Member Since: 01 Oct 2021 Location: UK Posts: 1472
Or loading the car.
l've had my coil sprung 90 Commercial loaded with a weeks camping gear including outboard motor, dinghy, bikes etc plus a caravan on the towbar and there's still no discernible change in the rear ride height
| walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2718
Ilkove the air suspension, the comfort is worth it, but also when hooking trailers up, use the adjust buttons in the boot to lift the car to hook up. So much easier than winding the jockey wheel. Lazy?? Quite possibly but it makes life so much easier 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
| All times are GMT |
