![]() | Home > Technical > Defender 110 Puma Starter Motor |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
You are probably best sticking with, LR, Denso or Bosch in that order.
LR probably being one of those brands. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18031 ![]() ![]() ![]() |
Changing it is a horrible job ,I'm afraid, it is so inaccessible.
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1108 ![]() ![]() ![]() |
If you plan on keeping the Defender, then go a reputable brand.
As for changing the starter motor. I prefer the slower way of doing it, which is removing the coolant hoses above the starter motor and feeding the starter through the top. You can then go under the car and twist the starter 90 degrees into position and do the bolts up from underneath. Just connect the live and earth before bolting the starter rock solid. 2017 5.0 V8 Supercharged RRS SVR 2008 2.4 110 Utility Station Wagon XS. |
robbo22 Member Since: 21 Oct 2023 Location: Leistershire Posts: 31 ![]() ![]() ![]() |
thanks for the quick replies! Do you rate Britpart as a decent brand?
Britpart is the brand of last resort. I'd sooner fit a starting handle.
^^^^ I was waiting for that response.
![]() ![]() It is true though, most Britpart items are not always that great. I once had a light lense from them, the plastic was so brittle it was broken out of the box as I opened it it was that poor a quality product. So I tend to always avoid that brand too, there are a few items that are okay. Starter motors are not one of the good items. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8480 ![]() ![]() ![]() |
I would buy dense or similar. Avoid britpart if at all possible even more so as this is not a job you will want to do again in a hurry. Cheers
I’ve order the denso unit this morning. Thanks again!
