Home > Technical > Defender 110 Puma Starter Motor
robbo22
United Kingdom 2009 Defender 110 Puma 2.4 HT Keswick Green
Evening all,
My starter motor went today. Started great, heard this rattle coming from the bell housing are/passenger footwell but wasn't sure exactly where. 10 miles down the road, battery light came on. arrived at shopping centre.. no restart. Thought the battery was knackered Bought a new one. Still no cranking.. RAC called. The mechanic checked the voltage at battery and power to starter motor. All readings correct.. Bumped it and got home, thankfully!
So my question is, which brand of starter motor do people recommend? Looking on LRParts, there's 3 options. Aftermarket, OEM or Denso. My usual approach is buy cheap by twice. Is this correct when it comes to starter motors?
Thanks in advance!
Post #1029777 29th Mar 2024 8:21pm
You are probably best sticking with, LR, Denso or Bosch in that order.
LR probably being one of those brands. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1029778 29th Mar 2024 8:32pm
Changing it is a horrible job ,I'm afraid, it is so inaccessible. Sad
Post #1029780 29th Mar 2024 9:17pm
BrickBox
If you plan on keeping the Defender, then go a reputable brand.
As for changing the starter motor. I prefer the slower way of doing it, which is removing the coolant hoses above the starter motor and feeding the starter through the top. You can then go under the car and twist the starter 90 degrees into position and do the bolts up from underneath. Just connect the live and earth before bolting the starter rock solid. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1029781 29th Mar 2024 9:22pm
robbo22
thanks for the quick replies! Do you rate Britpart as a decent brand?
Post #1029785 29th Mar 2024 10:13pm
Britpart is the brand of last resort. I'd sooner fit a starting handle.
Post #1029788 29th Mar 2024 10:45pm
^^^^ I was waiting for that response. Rolling with laughter Rolling with laughter
It is true though, most Britpart items are not always that great.
I once had a light lense from them, the plastic was so brittle it was broken out of the box as I opened it it was that poor a quality product.
So I tend to always avoid that brand too, there are a few items that are okay.
Starter motors are not one of the good items. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1029789 29th Mar 2024 11:10pm
jst
I would buy dense or similar. Avoid britpart if at all possible even more so as this is not a job you will want to do again in a hurry. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1029800 30th Mar 2024 9:10am
robbo22
I’ve order the denso unit this morning. Thanks again!
Post #1029823 30th Mar 2024 12:48pm
