![]() | Home > Puma (Tdci) > Rivet part numbers |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
You want what’s called a closed/sealed head rivet for them, eBay would be the place to look
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 677 ![]() ![]() ![]() |
The vehicle is built with these alloy sealed rivets with steel shanks - (standard rivet gun is fine)
You can’t get full aluminium pop rivets, the shanks need to be steel. https://www.ebay.co.uk/itm/182531559658?mk...media=COPY I think it is 14mm length for the cappings as top two pass through a coupe of layers. For filling rear holes use the shortest length available. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
Bear in mind head designs vary a little, they aren’t just standard rivets.
I seem to remember Britpart was the OEM supplier, the head is round conical and not domed like many generic rivets. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
jcw Member Since: 11 Sep 2016 Location: Gloucestershire Posts: 170 ![]() ![]() ![]() |
I’ve bought genuine LR031461 rivets for exactly the same purpose of filling some random holes in the rear bodywork.
I can’t remember what they cost but they weren’t much - ordered from Duckworth LR with free P&P. Here’s what they look like - do appear to be an aluminium head with steel pin ![]() Click image to enlarge |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1028 ![]() ![]() ![]() |
https://parts.jaguarlandroverclassic.com/lr031461-rivet.html 2017 L494 Range Rover Sport SVR
2008 2.4 110 Utility Station Wagon XS. |
People will pay nearly £1 PER RIVET !
![]() Crikey. They should only be pennies each, there is nothing special about them. Go to a fastener specialist. |
Waka56 Member Since: 08 Nov 2023 Location: Hamburg Posts: 171 ![]() ![]() |
I see some britpart for 20pi
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 232 ![]() ![]() ![]() |
But it does come individually wrapped in its own branded plastic bag ![]() |
