![]() | Home > In Car Electronics > Central locking plug |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Not sure it is available as just the plug from LR. It is a Tyco MQS connector that you want though. Freely available from RS etc.
They are very fiddly to reliability crimp and assemble. It would be better to get a new door loom with the connector fitted or alternatively see if Paul MC or Martin can do one with flying leads. Steve 02' 110 TD5 Double Cab Rebuild Thread |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6681 ![]() ![]() ![]() |
LR part number is YPC110710 or LR052168, about £4+VAT
This is just the bare housing. I can supply a housing with terminals and seals or with repair wires pre-installed. About £7-£8 posted ![]() ![]() ![]() |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
Thank you Steve and Martin.
Could i have 1 to start with Martin with cables fitted please? If it works with these actuator then i'll order the other 3 ![]() Are they available from the shop or direct through you? Cheers |
drives door one has added core over n/s for lock feed back to the alarm unit
I already have all the plugs and set up
![]() I swapped the current doors for split doors but want to see if i can custom fit some actuators. Makes sense to use the system if it's already in place. |
PM replied to
L90RNP Member Since: 11 Mar 2024 Location: bedfordshire Posts: 6 ![]() ![]() |
Just found this thread, Do you still supply this connector with wires pre-installed? I also need the drivers door one with the 4 wires pre-installed also two of the 2 pin power connectors for the electric windows with 2 wires pre-installed. my cables have all fractured in the rubber conduit from bulkhead to door. Ray. |
Would all those (inc the elec window connectors) be for the bulkhead pillar end?
Correct, bulkhead pillar end of each door harness (driver and passenger)
Sorry for delay, yes I can do all of these
Hi, all sorted now.
Many thanks. Ray |
pistonfields Member Since: 29 Mar 2022 Location: Zurich Posts: 76 ![]() ![]() |
Does somebody have the actual manufacturer part number / part name of both door frame side and actuator side connector? Wanting to crimp cables myself as I have everything including good tools, but not the name of the connector.
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
The connectors are TE (Tyco / AMP) MQS Sealed Series.
The connector housings can be found individually, but terminals and seals have to be bought in bulk, usually 100 pieces minimum. I, and others (including Martin, Admin on here), sell the connectors as a kit of all the parts needed. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
johnnyeebaby Member Since: 31 Mar 2024 Location: Ireland Posts: 3 ![]() ![]() ![]() |
Hi Martin,
Ive just registered on the Forum, Could you PM me please I'm Looking for Male Connectors for the Central locking and Electric window door pillar plugs. Thanks John |
