Home > In Car Electronics > Central locking plug
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Does anyone know the part number for central locking actuator plug?
Not this part, but the one that plugs into this;
Tia
Post #836748 12th Jun 2020 12:06pm
rallysteve
Not sure it is available as just the plug from LR. It is a Tyco MQS connector that you want though. Freely available from RS etc.
They are very fiddly to reliability crimp and assemble. It would be better to get a new door loom with the connector fitted or alternatively see if Paul MC or Martin can do one with flying leads.
Post #836752 12th Jun 2020 12:56pm
Martin
Site Admin
LR part number is YPC110710 or LR052168, about £4+VAT
This is just the bare housing. I can supply a housing with terminals and seals or with repair wires pre-installed.
About £7-£8 posted Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #836754 12th Jun 2020 1:04pm
Badger110
Thank you Steve and Martin.
Could i have 1 to start with Martin with cables fitted please?
If it works with these actuator then i'll order the other 3 Thumbs Up
Are they available from the shop or direct through you?
Post #836846 12th Jun 2020 6:36pm
dorsetsmith
drives door one has added core over n/s for lock feed back to the alarm unit
Post #836864 12th Jun 2020 8:12pm
Badger110
I already have all the plugs and set up Thumbs Up
I swapped the current doors for split doors but want to see if i can custom fit some actuators.
Makes sense to use the system if it's already in place.
Post #836955 13th Jun 2020 10:53am
Martin
Site Admin
PM replied to  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #836992 13th Jun 2020 3:14pm
L90RNP
Just found this thread, Do you still supply this connector with wires pre-installed?
I also need the drivers door one with the 4 wires pre-installed
also two of the 2 pin power connectors for the electric windows with 2 wires pre-installed.
my cables have all fractured in the rubber conduit from bulkhead to door.
Ray.
Post #1027593 11th Mar 2024 12:10pm
Martin
Site Admin
Would all those (inc the elec window connectors) be for the bulkhead pillar end?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1027645 11th Mar 2024 5:45pm
L90RNP
Correct, bulkhead pillar end of each door harness (driver and passenger)
Post #1027655 11th Mar 2024 6:41pm
Martin
Site Admin
Sorry for delay, yes I can do all of these Smile I'll drop you a PM  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1027889 13th Mar 2024 9:55am
L90RNP
Hi, all sorted now.
Many thanks.
Ray
Post #1028378 17th Mar 2024 8:35pm
pistonfields
Switzerland
Does somebody have the actual manufacturer part number / part name of both door frame side and actuator side connector? Wanting to crimp cables myself as I have everything including good tools, but not the name of the connector.
Post #1029903 31st Mar 2024 10:32am
PaulMc
The connectors are TE (Tyco / AMP) MQS Sealed Series.
The connector housings can be found individually, but terminals and seals have to be bought in bulk, usually 100 pieces minimum.
I, and others (including Martin, Admin on here), sell the connectors as a kit of all the parts needed. Paul.
Post #1029968 31st Mar 2024 7:24pm
johnnyeebaby
 2002 Defender 90 Td5 CSW Barolo Black
Hi Martin,
Ive just registered on the Forum, Could you PM me please I'm Looking for Male Connectors for the Central locking and Electric window door pillar plugs. Thanks John
Post #1029989 31st Mar 2024 11:03pm
