![]() | Home > Maintenance & Modifications > Heavy duty or single piece half shafts? |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2489 ![]() ![]() ![]() |
Does anyone measured the diameter of these 1 piece halfshafts? Puma 110" SW
nicholas2012 Member Since: 28 Jun 2012 Location: lanarkshire Posts: 197 ![]() ![]() ![]() |
I think the diameter looks to be the same as the standard puma half shafts but removing the weakpoint of the outer splined drive flanges that always wear
![]() ............................................................. Earth first. Other planets later |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
Just been having a look at this thread as my DM’s could do with externally greasing again, I’ve got no problems with mine touch wood and running Ashcroft 2 piece rear.
Ashcroft HD flanges front, rest genuine front. Blackwolf - Did you ever manage to get around to fitting a grease nipple to any HD DM caps? I would like to do that, but the problem is with them currently fitted and the work involved it’s easier just to have some caps to swap over which isn’t cheap… I wonder if the Terrafirma versions would fit and as it’s just caps I wonder if they would swap over, they are a lot cheaper. Presumably the clearance is there in the centre of the alloy behind the centre cap and the DM cap with a grease nipple in the centre or would it need offsetting. Would certainly be a lot faster and easier to grease, than having to take the caps off and also more effective. I was thinking of using aerosol lithium into the splines as the pressure should help get it into the splines more effectively. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
No, I went for single-piece halfshafts at the rear, the fronts are still Ashcroft HD with standard caps and seem to give no trouble.
I remember, that’s good. So I take it that you still just manually grease the front splines and all is okay.
![]() Though off topic, the A frame ball joint and bushes are also a common cause of a sloppy or loose rear often confused with rear driveshaft components. Mine was much better after the greasable A frame ball joint and A frame bushes were replaced. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2274 ![]() ![]() |
LRA: exactly as Iv found my front passenger side. Is it only a matter of removing the circllip 6 flange bolts and greasing the inside? Cheers Keith. ![]() Click image to enlarge |
Hi Keith,
Essentially yes, although bear in mind that grease won't cure an already worn joint. You'd have to judge if it's already too far gone. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thanks Daren. Tuesday will see the job done and right on cue these have arrived super quick postage from Ashcrofts.
Lovely bit of kit, and HD.
![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
