|  | Home > Puma (Tdci) > Defender 2.4 Puma TDCI New engine fitted and guess what? |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6060    | It doesn’t help you, but I doubt engine would start, and run so well if incorrectly timed. I think your problem must be something else.
 A new VCV would always be my starting point on these engines. | ||
|  1st Mar 2024 9:53pm |
| Jensen Member Since: 05 Jan 2013 Location: Poitou Charentes-France Posts: 20    | Thanks for your reply !
 Totally agree with you ! Best of my knowledge you Can’t check the timing now it’s all sealed and back together . The VCV was relatively new on old engine/pump . Never did a relearn because you can’t with nanocom ? But it was fine all the same . | ||
|  1st Mar 2024 11:26pm |
| Jensen Member Since: 05 Jan 2013 Location: Poitou Charentes-France Posts: 20    | Surely if the timing was so far out that the pistons were hitting the valves there would be starting problems, smoke and diesel knock, fault codes ??
 I want to be sure before I strip it down again to check timing ! | ||
|  2nd Mar 2024 3:24pm |
| Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 628    | It won’t bend a valve is mistimed just break a cam follower bolt or the ladder assembly. Would run like a bag of crap too | ||
|  2nd Mar 2024 3:55pm |
| Jensen Member Since: 05 Jan 2013 Location: Poitou Charentes-France Posts: 20    | Yeh ! That’s what I thought .
 If it was hitting the valves you would think you could hear It through the followers etc But you can’t ? | ||
|  2nd Mar 2024 4:57pm |
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681      | Injectors in tight? Blowing out past them? | ||
|  2nd Mar 2024 8:42pm |
| Jensen Member Since: 05 Jan 2013 Location: Poitou Charentes-France Posts: 20    | Yes ! Injectors are tight ! 6nm + 180 *
 Checked them twice ! Probably don’t like that 2 bolt system  | ||
|  2nd Mar 2024 10:05pm |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512      | Was the CKP holder already in place in the new engine? To my knowledge this setup is done before the cylinder head is installed. I may be wrong...
 As well, make sure the injectors are original Denso and not counterfit. It can be very difficult to spot the difference. Puma 110" SW ............................................................. Earth first. Other planets later | ||
|  3rd Mar 2024 1:15pm |
| Jensen Member Since: 05 Jan 2013 Location: Poitou Charentes-France Posts: 20    | Hi
 Yes the crank sensor holder was already on and bolted up. The engine came from a very reputable UK engine refurbisher who also supplied the Denso injecteurs | ||
|  3rd Mar 2024 1:25pm |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512      | I would try using the older injectors. Puma 110" SW
|  3rd Mar 2024 1:46pm |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512      | Is it so audible to upload an audio? Puma 110" SW
|  3rd Mar 2024 5:32pm |
| SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296      | My 2.4 had been making a ticking sound, that I couldn't find the source of.
 I had the clutch replaced when I switched to the Ahscroft output shaft and it resolved the ticking. So could it be coming from the clutch? 2011 CSW XS 90 | ||
|  4th Mar 2024 9:11am |
 I don’t know ? Will have to put a vid up on YouTube and link to it ? | ||
|  4th Mar 2024 8:01pm |
 Thanks for that but I changed the clutch etc last year when I changed the gearbox/transfer input Shaft for the Loff one ! It was making a noise before or after ! | ||
|  4th Mar 2024 8:07pm |
| Posting Rules
