Home > Puma (Tdci) > Defender 2.4 Puma TDCI New engine fitted and guess what?
Jensen
France
Hi
After searching high and low for a 2.4 TDCI engine after ours died lasyt year with over 300K Km's we eventualy bit the bullet and bought a brand new one which was sent out to France with 4 new injectors etc.
Timed new engine up with the injection pump off the old engine using varios corresponding tutorials off the internet, programmed new injectors useing nanocom evo . Swapped all the auxillaries over useing new gaskets, water pump etc , filled with oil, coolant, turned engine over first on the starter with the crank sensor disconected to prime with oil and she fired up first time . Let her get up to temperature on tick over and all was good, no leaks, everthing spot on !
But : There is a tapping ! Can only be heard above tick over and when the engine is warm ? Starts and runs absolutely spot on, no smoke, no engine fault codes but as soon as she gets up to temperature there is a rev related tapping ?
Engine supplier thinks that the timing is out and its the pistons hitting open valves ?
Knowing that the timing was the most important point of this operation I took a lot of time to maticuously set it by the book ! Engine supplier since suplied procedure and corresponds with exactly how it was done .
( 2 x cam cogs locked with 6mm drills, flywheel locked with special tool through crank shaft sensor holder, 3 black links on chain lined up with arrows on cam cogs and hole in injection pump cog etc )
We have listened with a stepthoscope over every inch of the engine, scratched heads, checked , re-checked, injectors bolts etc to no avail .
Absolutely unbelievable ! Just can't believe it !
if anybody could shed any light it would be much appreciated.
Thanks in advance
Post #1026502 1st Mar 2024 5:53pm
landy andy
It doesn’t help you, but I doubt engine would start, and run so well if incorrectly timed. I think your problem must be something else.
A new VCV would always be my starting point on these engines.
Post #1026528 1st Mar 2024 10:53pm
Jensen
France
Thanks for your reply !
Totally agree with you ! Best of my knowledge you
Can’t check the timing now it’s all sealed and back together .
The VCV was relatively new on old engine/pump . Never did
a relearn because you can’t with nanocom ? But it was fine all
the same .
Post #1026538 2nd Mar 2024 12:26am
Jensen
France
Surely if the timing was so far out that the pistons were hitting the valves there would be starting problems, smoke and diesel knock, fault codes ??
I want to be sure before I strip it down again to check timing !
Post #1026588 2nd Mar 2024 4:24pm
Siwynne
It won’t bend a valve is mistimed just break a cam follower bolt or the ladder assembly. Would run like a bag of crap too
Post #1026590 2nd Mar 2024 4:55pm
Jensen
France
Yeh ! That’s what I thought .
If it was hitting the valves you would think you could hear
It through the followers etc But you can’t ?
Post #1026595 2nd Mar 2024 5:57pm
NickMc
Injectors in tight? Blowing out past them?
Post #1026613 2nd Mar 2024 9:42pm
Jensen
France
Yes ! Injectors are tight ! 6nm + 180 *
Checked them twice ! Probably don’t like that 2 bolt system Sad
Post #1026623 2nd Mar 2024 11:05pm
MK
Was the CKP holder already in place in the new engine? To my knowledge this setup is done before the cylinder head is installed. I may be wrong...
As well, make sure the injectors are original Denso and not counterfit. It can be very difficult to spot the difference. Puma 110" SW
Post #1026673 3rd Mar 2024 2:15pm
Jensen
France
Hi
Yes the crank sensor holder was already on and bolted up.
The engine came from a very reputable UK engine refurbisher who also supplied the Denso injecteurs
Post #1026674 3rd Mar 2024 2:25pm
MK
I would try using the older injectors. Puma 110" SW
Post #1026677 3rd Mar 2024 2:46pm
MK
Is it so audible to upload an audio? Puma 110" SW
Post #1026713 3rd Mar 2024 6:32pm
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
My 2.4 had been making a ticking sound, that I couldn't find the source of.
I had the clutch replaced when I switched to the Ahscroft output shaft and it resolved the ticking.
So could it be coming from the clutch? 2011 CSW XS 90
Post #1026766 4th Mar 2024 10:11am
Jensen
France
I don’t know ? Will have to put a vid up on YouTube and link to it ?
Post #1026857 4th Mar 2024 9:01pm
Jensen
France
Thanks for that but I changed the clutch etc last year when I changed the gearbox/transfer input
Shaft for the Loff one !
It was making a noise before or after !
Post #1026861 4th Mar 2024 9:07pm
