![]() | Home > Puma (Tdci) > Passengers Manual Windows - slides down |
| X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304
Hello webbug
Please forgive me joining your post as I too would like to know the answer to this. Firstly I didn't know it was a common problem (Landrover My Wife's 110 has had this on the rear off side (RHD Vehicle), 15mm each time. My local independent said Oh Yes, we have solved this by using a heavier water pump grease on the mechanism, counter intuitive, but it worked. My intention is to get the door cards off both rear doors and have a look / play around, to see if there is any perceived difference and go from there. Someone may well come along with more insight here so lets see where this goes. Thanks... https://www.defender2.net/forum/topic83242.html |
| ScarboroughSeadog Member Since: 21 Jul 2022 Location: Scarborough Posts: 110
Oh yes- mine does the same! Wife always suspected our two year olds feet were doing it......I'm not so sure!
| TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1362
Mine does too and I have the impression that there is a foam block glued to the inside of the door panel in such a way that it creates pressure and friction on the crank handle once fitted.
The foam block can unglue itself and thus leaving the crank handle to fit loosely without any resistance and holding power. I have changed the window crank mechanism (before I came up with the foam block theory) but that made no difference. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18031
All second row door windows are prone to it. I initially solved by hooking an elastic bungee round the window winder, this worked but wasn't exactly convenient.
The permanent and best solution was to convert the second row windows to electric lifters. Problem solved, and you can operate the from the front while driving. |
| rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 891
My fix for this is to orientate the winder handle so that gravity acts on the handle so it doesn't wind the window down
| khamuul Member Since: 14 Oct 2017 Location: Teutoburg Forest Posts: 27
"elastic bungee" - best solution so far.
Winding up and down is still possible, windows stay reliably closed and you get an extra towel hanger for camping. |
That is exactly how I did it before I fitted the electric lifter kit.
| HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 818
Asides from the electric window conversion (Which I am saving up for), you can also reposition the handle so it points straight down or as close to it as possible. I found that this stopped my rear windows from inching down on their own. A down side of this is sometimes the rear passenger's knee can hit and turn the handle enough to cause a small gap.
Great ideas- the elastic bungee solution looks straightforward and effective...made me smile as well!
| Daysleepers Member Since: 15 Dec 2022 Location: Suffolk Posts: 111
I am installing the elastic bungee solution this evening. Great idea!
You are lucky if you can find an elastic bungee like this one at your local home improvement store for this job:
| Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3361
Give it a couple of clockwise turns before fitting and you will have a Twisted performance version. Got to be worth at least an extra 5 bhp. WARNING.
This post may contain sarcasm. |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
This was a built in feature by Land Rover. The Defender had an image of appealing to an older age group and Land Rover were trying to push it towards a younger age group of buyers. The rational behind the self opening window being, that you could take your take your partner for a drive to a secluded spot and have some nudie nookies . The window would be slightly down (automatically, I might add) to allow fresh air into the vehicle during the proceedings and hopefully keep sweating to a minimum. 1982 88" 2.25 diesel
