![]() | Home > Puma (Tdci) > 2 Stroke oil in diesel. |
John110 Member Since: 20 Nov 2011 Location: Co. Meath Posts: 106 ![]() ![]() ![]() |
![]() For those who do not understand, no explanation is possible |
Stornaway90 Member Since: 28 Apr 2011 Location: Gods Country (Cornwall) Posts: 48 ![]() ![]() ![]() |
Well, I finally rolled over and added Acetvo 2 stroke oil to my Defenders Diesel tank, the results from one tank full and 328 miles are listed below:
1. Engine is a little quieter when cold 2. Engine is considerably quieter when warm with a slightly different tone. (Less like a Diesel especially on the overrun) 3. When starting from hot and cold, it takes a nano second longer to spring into life 4. No smoke when either hot or cold, but there wasn't any anyway (just covered 8000miles) Other than the listed items above, there does not seem to be any improvement in the vehicles performance, still getting around 330 miles to a tank which I don't think bad at all, if your are after 50 plus miles to a gallon you need one of those noddy cars like a C1. Will I add more 2 stroke, probably yes, but i am due to change to a new 110 XS shortly and I will be adding this to that vehicle from the minute i get it. Just in case!!! One Life Live It, There Isn't Anything To Beat It, Even The Boss Agrees. Defender 110 2012(XS) Defender 90 2011 (XS) Gone. Defender 90 2008 (County) Gone. Triumph Bonneville (SE) Gone. www.landywatch.co.uk |
With my td5, I frequently used a bit of old engine oil in it.
In spring, I would change the engine oil (not gear oil) in the Land Rover, the Car, Motorbike & 2 lawnmowers. I had about 4 gallons of used engine oil (worth over £20 in fuel prices). I bought a filter bag off ebay, and filtered the oil to ensure it was clean (can't remember the filter, but IIRC it was around 5 microns, which was slightly finer than the fuel filter). Dropping a litre into each tank fill of diesel saved me over a quid every time, made the vehicle run smoother, and saved me the trip to the recycling centre to dump the oil in an environmentally friendly way... anyone do this on a Puma??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Would the customs not frown uopn this as It would mask the colour of the diesel? For those who understand, no explanation is needed... For those who do not understand, no explanation is possible |
Engine oil isn't good because it produce ash when burned and deposit like glass on the injectors!!! 2SO in made for burn into the combustion process and it helps to mantain W/O ash and dposit the injectors (and reduce fuel system wear). Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
not to mention all the gunk that it removed from the engine, including sulphuric acid! It's like adding urine to your drinking water - crazy! ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Correct you said ![]() ![]() IID Pro MV License |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 ![]() ![]() ![]() |
You'll be fine on it - it works a treat, but remember that the mpg gains take a few at tankfulls to take effect
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
I have been using 2T for the last 6 months or so, but just for a change, and as the warning light came on i have filled up with BP Ultimate an no 2T.
it will be interesting to see if there is a noticeable difference reverting to just diesel! BM52 |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4810 ![]() ![]() |
Picked up a 1 litre bottle of Tesco motorcycle oil 2 stroke, today for £4.99. Does not say if it is mineral or synthetic but at that price I'd guess mineral based.Says it is formulated from "selected base oils" and is FB spec.Anyone know for sure?. Have been using Castrol Activo but decided to dumb down to the FB spec.
Could get a 5 litre bottle of chainsaw lubricant at the local co-op for €8.99, but there is no info on it whether it is mineral or synthetic or what spec it is. Just says "anti-fling" for chainsaws. Anyway gave it a miss owing to the lack of info. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
google the specs, there a standard. FB is low ash mineral from my memory of last search. cheaper the better i'd say. I'll sling some in the new one tomorrow |
Yep, have been googling away but cannot get exact brand matches. From what I have found out is that for €8.99 for 5 litres it has to be mineral based but hard to know the specs. It can hardly be FC spec but is there anything lower than FB sold on the market? 1982 88" 2.25 diesel
yes theres a FA look at this link http://www.7thgear.net/7thGear/Default.aspx?tabid=27 best deal i've found http://www.ebay.co.uk/itm/290481665920?ssP...906wt_1344 |
Yep saw that, just wondering if the chainsaw oli is 2 stroke. 1982 88" 2.25 diesel
